Neutral safety switch on a 727 #1622321
05/19/14 05:03 PM
05/19/14 05:03 PM
Winnipeg, Manitoba, Canada
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Should I put Teflon tape on the threads when installing a new neutral safety switch in a 727?
Re: Neutral safety switch on a 727 [Re: 4dr4x4] #1622322
05/19/14 05:18 PM
05/19/14 05:18 PM
Guitar Jones Offline
No, it's a ground point. It should have a sealing gasket.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Neutral safety switch on a 727 [Re: Guitar Jones] #1622323
05/19/14 05:23 PM
05/19/14 05:23 PM
scratchnfotraction Offline
sometimes the black coating/sealer gets chewed up on the comp ring so I use a little of the mopar black ATF/RTV on the ring to case edge but dry on threds.
Re: Neutral safety switch on a 727 [Re: 4dr4x4] #1622324
05/19/14 05:36 PM
05/19/14 05:36 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Thanks, I just wanted to make sure.
