Re: port velocity?
[Re: mopar dave]
#1622139
05/19/14 01:23 PM
05/19/14 01:23 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
If there is not enough velocity then the fuel falls out of the air and does not burn properly. Too much and it can slam the fuel into the outside of the curves and seperate it that way. I don't know what numbers to shoot for I just tend to stick with what works.
Re: port velocity?
[Re: mopar dave]
#1622142
05/20/14 10:10 AM
05/20/14 10:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
ok, so is there a way to pick the ideal bore,stroke,rod length and port cross section using the math for port velocity?
I dont know what that would be but I'm sure there is... I just look at my header program in the calculate HP and it shows the cross section needed and what RPM.. its based on the stroke you enter ![](/ubbthreads/images/graemlins/wave.gif)
Re: port velocity?
[Re: MR_P_BODY]
#1622146
05/20/14 04:12 PM
05/20/14 04:12 PM
BradH
300 fps seems to be the magic number for most to shoot for
Average? Peak? Measured where?
Without some context, that 300 fps value doesn't mean much.
Re: port velocity?
[Re: AndyF]
#1622148
05/20/14 05:00 PM
05/20/14 05:00 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Like most other particulars, it is design specific.
For example.....
Try to up the port velocity over a bad short turn and see what happens.
Re: port velocity?
[Re: BradH]
#1622149
05/20/14 06:30 PM
05/20/14 06:30 PM
MR_P_BODY
I will assume its the average of the port... I get the data from PipeMax which is a pretty damn good program for a ton of info ![](/ubbthreads/images/graemlins/wave.gif)
Re: port velocity?
[Re: MR_P_BODY]
#1622150
05/20/14 08:19 PM
05/20/14 08:19 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
My guess is that unless a person is building a high end motor like pro stock or a " class" type motor this stuff is best left in the hands of an accomplished head porter who is armed with the basics of a combo and it's intended use. The longer the stroke with a given head the lower rpm a motor needs to be spun to make peak horsepower, and peak torque will come in sooner as well. I would plan the combo around how much you plan to invest in valve train components, and how long you want the motor to live. Those will dictate how big an arm can be used with the intended head. All the above assumes the OP isn't building a pro stocker or a trick " class" car ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: port velocity?
[Re: AndyF]
#1622155
05/21/14 01:21 AM
05/21/14 01:21 AM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
360 small block with indy 360-1 heads. so you think a 3.79 stroke would be a good combo/most efficient with these heads? better than a 4" stroke?
Re: port velocity?
[Re: mopar dave]
#1622156
05/21/14 01:38 AM
05/21/14 01:38 AM
MR_P_BODY
Dave if you have PipeMax dont you put your engine combos through it to see what you get... biggest thing is getting the volumetric efficiency correct ![](/ubbthreads/images/graemlins/wave.gif)
