Is the 360 an inherently inefficient engine?
#1622022
05/19/14 06:04 AM
05/19/14 06:04 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Dont know HOW many times i've heard this. Never once has someone not knocked the inefficiency ov the 360... whether old style LA, or the newer Magnums (except ME... i thought my 78 Volare 360-2bbl was great on gas). Looking at ratings, the math makes the 318 far better for its size than the 360. I've rarely heard anyone rag on the 318 for its piggishness, or really, even for its sluggishness. Most 318 owners were happy with it for what it was, a far rarer sentiment with 360 guys, especially Magnum guys.
Personally... i cant see how one relatively similar engine (360) can suck at efficiency when such a close relative (318) doesn't (lets say both are Magnums). It seems to me more an issue ov installation, tune, accessories. I know they pooched the factory tune on the 360 Magnums. Maybe the exhaust/intake is already too small for the 318, and dumping it on the 360 further chokes it up?
I have a very light car (will be 3000lbs), with a stick, and it'd be nice to be as fast as a 12 second car from a roll (its not a drag car). I found a really nice 318 Magnum ('95 Ram), and i am really trying to find a reason why i need a 360? What i DONT want... is a pig. If i wanna suck gas i'll stick with the 400 lowdeck. Quite honestly... my 96 4.6L Mustang (3400lbs, 215HP) goes almost fast enough for what i need... a 318 Magnum as installed (Dougs headers, full race exhaust, RPM air-gap, Holley, cam, etc.) should make far more power, and in a lighter car.
Do i keep looking for a 360? Instinct tells me the 318 Magnum (with my mods) should be plenty fast and efficient in a 3000lb stick car.
Re: Is the 360 an inherently inefficient engine?
[Re: BigBlockMopar]
#1622024
05/19/14 07:25 AM
05/19/14 07:25 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
360 is a "stroker motor" compared to a 318, will make a lot more torque than a 318 will all being equal.
I have a 5.9 in my Duster, I'm very happy with it. I'll take any you want to get rid of.
"I think its got a hemi"
[Re: gdonovan]
#1622025
05/19/14 08:32 AM
05/19/14 08:32 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I think people tend to compare the 340 to the 360 (which replaced it) and the 360 did have a poor power/tune compared to the 340 despite the 20 extra cubes. I'm thinking the 360 (like the 400) was built with emissions in mind and less for performance. If you are satisfied with the 'Stang and have the 318 already, I'm sure you would be more than happy just building it and skip trying to find a 360. Of course, if you are looking for the most power, the 360 is the way to go. If I were building a motor (and had both engines to choose from), I'd take the bigger displacement of the 360 over the 318. I think you will have an advantage with the extra cubes if you are willing to build it with performance parts as opposed to leaving it bone stock. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Pale_Roader]
#1622026
05/19/14 09:12 AM
05/19/14 09:12 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
You ought to clarify what you mean by "inefficient".
Do you mean less capable of turning a pound of fuel into an hour of horsepower, or do you mean less capable of making of making high horsepower at high rpm?
The 360 has relatively large main bearings, which may be good for low rpm heavy torque towing duties.
This beefed up lower end also makes it about 57 lbs heavier than a 318, but race shops like Petty Enterprises found plenty of places on the stock block to machine away unnecessary and non-load bearing weight.
Nearly all the American V8 manufacturers found that Honda's redesign of main bearing were both smaller, less friction and capable of higher rpm.
The internally balanced 318 has one of the highest rod/stroke ratios which has inherent low friction advantages, and can allow slightly higher dynamic compression rations. The 360 is only slightly less.
For high rpm horsepower production, cylinder head breathing mostly dominates, and valve size (and number) in turn is very important.
Canted and opposed (Hemi) valve arrangements allow larger diameter valves and straighter runners than side by side valve Wedge designs in cylinders of the same diameter, so a 5.7 Hemi has a high rpm breathing advantage over a Magnum 5.9 Wedge.
When comparing pickup truck duty Magnum 5.2 to Magnum 5.9 the dominant thing is the beer barrel intake manifold, which was designed for the 5.2 and when this 15.5 runner length intake manifold is bolted unmodified on a 5.9 brings peak torque and horsepower in at lower rpms.
Drag racers consider this as choking off performance above 4000 rpm.
For working pickup truck use available low rpm torque is a good thing.
If you want to fault a particular feature of both 5.2 and 5.9 V8s, one very questionable area is: why are the Quench clearances of piston to head so much larger than 0.026 inches, (0.047 plus 0.055) and why are the factory dynamic compression ratios so relatively low?
The probable answer is that cylinder to cylinder quality control at the factory was so variable that a large average Quench clearance was necessary to keep "statistical outlier" tight cylinder piston fits from hitting the cylinder head and generating a costly to Chrysler warranty claim.
[Re: 360view]
#1622027
05/19/14 09:53 AM
05/19/14 09:53 AM
Posts: 22,732 Bitopia
jcc
Bitopia
And push rod angles a bit on the extreme side for performance applications
[Re: jcc]
#1622028
05/19/14 11:27 AM
05/19/14 11:27 AM
RapidRobert
Take advantage of the addit'l 42 cubes. adequate SCR. matched bolt on components for the short block. 040" quench. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: rapom]
#1622036
05/19/14 06:44 PM
05/19/14 06:44 PM
Posts: 4,704 Wichita
GY3
Wichita
Low compression on the 360 when compared to the 340's is the culprit.
I have a 360 with 9.5:1 and a 750 3310 Holley. It's as efficent as you're gonna get in a 5,600 lbs. Powerwagon with full time 4wd. It does get better mileage than the 318 2 bbl. it replaced.
11 mpg average for the 360 and 9 mpg average for the 318 with LOTS more grunt and towing capability.
[Re: MoparforLife]
#1622038
05/19/14 09:36 PM
05/19/14 09:36 PM
dogdays
I had some friends who were driving government fleet vehicles, Dodge Durangos, it was widely known and they confirmed that the 5.9 Mag got better mileage than the 5.2.
Going back to the 1974 Duster, the 360 most always was a gas hog. Now I don't know why, but stock it had a bigger cam and bigger ports than a 318, for most of the production run. Many also had a four barrel carb while the 318 never had a 4-barrel until the very late cop cars. We had a mid'70s Dodge W250 on the site with full-time 4wd. That would knock down 6mpg, no improvement no matter how you drove it.
Now there is no earthly reason why a 360 would have different economy characteristics than a 350 chevy, but they seemed to. During the '70s, neither one had much compression and neither had a cylinder head with squish.
If you have a 5.2 Mag on a stand I say build it. The reports on them from Board members is that with proper tuning and a few hotrod parts they will make power equal to an LA 360 but with quite better mileage. That's for street engines.
If you really want more power stick a 4" crank in the 5.2 and go to town.
Before I'd put a 5.2 on the shelf for a 5.9, I'd find a G3 Hemi. That's significantly lighter and stronger, also more efficient.
R.
[Re: dogdays]
#1622039
05/19/14 10:38 PM
05/19/14 10:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
In my 87 Diplomat I ran both a 318 and a 360. Both with 4bbl setups and similar cams.
The 318 got maybe 3-5 more mpg highway vs the 360, but the 360 was quicker and faster, probably 20 mph more top speed.
Best combo for my setup was the 360 with the 87 318 heads, Comp XE262 cam. Lots of torque, good mileage and good passing abilities. 20-22 mpg highway was common with that setup.
[Re: Jim_Lusk]
#1622041
05/20/14 01:47 AM
05/20/14 01:47 AM
Posts: 516 ND
dodgedon
ND
The 360's in trucks that i have seen always had lower gears in them. 3/4 and 1 tons had 4:10 and lower gears. If it was a half ton it had 3:91... The 318's I have seen in 1/2 tons in the 70/80's had 3:23 gears and in the 90's and up had 3:55's Those low gears realy hurt MPG.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
