Big block options/ideas for '66?
#1619417
05/12/14 07:22 PM
05/12/14 07:22 PM
Posts: 46 MO
Bayoulee
MO
I'm looking for info on big block options for my 66 Sport Fury auto. At first, I researched some easy(er) upgrades on the 318 such as a intake, 4bbl, cam, headers etc. Pricy. I think I can find a drop in motor for the costs of those things. I have a buddy with a 71 413 in a Winnebago that runs, so I thought that an option. Someone said a 383 or 400 would be the best options, as a 413 is going to be a lot of work to get to fit, i.e. water pump, oil pan, exhaust, other parts that dont fit, etc. Id like to find something to change out motor mounts, radiator and drop right in with minimal issues. all opinions and recommendations appreciated.
Re: Big block options/ideas for '66?
[Re: dogdays]
#1619419
05/12/14 08:16 PM
05/12/14 08:16 PM
Posts: 15,487 Florida
scratchnfotraction
as long as the 413 is not a 8 bolt crank HD truck engine with its own specific WP/housing/exhaust manifolds...it may be a drop in with a BB727. some of those 413s are same as a car 413 that can be made right into a 426 wedge engine. ID what your buddy has for sure before you decide to pass on it. I am going to get the one I found..every one said it was the HD truck 413...NOT! 250$ and coming home with me. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Bayoulee]
#1619421
05/12/14 08:36 PM
05/12/14 08:36 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The 413 can be a torquey little guy but don't plan on rebuilding it in the future unless you enjoy spending money. The pistons are unobtanium and must be custom made in most cases.
[Re: dogdays]
#1619425
05/13/14 05:04 PM
05/13/14 05:04 PM
feets
Senior Management
Senior Management
Irving, TX
Some MHs had a parking brake mounted on the transmission tail shaft. If so, a donor trans will need to be found.
[Re: RapidRobert]
#1619429
05/14/14 09:41 AM
05/14/14 09:41 AM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
I have owned many 413 s and some were motor home engines , some truck engines and standard car engines . I believe they may have had different cams and heads as the truck engines could not rev like the car engines but could lug for ever. save the cam gears on the truck engine as there is no timing chain but not sure if the cam gear will go into a standard housing. A friends dad had one of those old dodge motorhomes circa 66 all fiberglass and no corners. It had badge on the side about 4' sq. that said 413 Super High performance. So I pulled the engine cover and saw the biggest set of manifolds I have ever seen . It had a monster Holley carb on it too. You grab the RB and there are lots of B and RB parts that will fit . Good Luck with it . ![](/ubbthreads/images/graemlins/beer.gif)
[Re: mopar_man]
#1619430
05/14/14 10:04 AM
05/14/14 10:04 AM
Posts: 2,346 west palm beach, florida
modelmakerinc
A truck or RV engine is adding complications for no reason, the exhaust may or may not work the oilpan, and pickup will need to be swapped out with the correct c-body pan, the waterpump is likely to be a passenger side inlet which causes radiator fitment difficulties.
There are bunches of 66-73 c-bodies with running 383's and 440's that can be had for 800 to 1600 and you will have all the parts, engine, trans, plus lots of clips and hardware and other parts that were used trough the years on these cars , And with the right parts car you can get the brake system out for yourself or sell to others wanting to upgrade brakes.
[Re: mikemee1331]
#1619434
05/14/14 11:52 AM
05/14/14 11:52 AM
scratchnfotraction
dont rule out the MH RB engines. my 78 lopo 440 from a MH and 78,000 miles on it really woke up my 88 swb truck. shave 40 foot of MH, add a RPM intake/q-jet/duels/3.91sg and it is a killer street cruzer. ![](/ubbthreads/images/graemlins/drive.gif) the 413 I am looking to get has wedge heads and looks just like a car engine, even has headers on it (not the big truck manifolds specific to HD/IND-413s) not sure what wedge heads but looks about like my MH 440 does. my trans was a short shaft bolt on yoke, bolted right in the stock location but I had to build a drive shaft with a slip yoke.
