Re: Totally Anal Small Block Details- 318/340/360 1972 & Up
[Re: ScottSmith_Harms]
#1837922
05/31/15 11:47 AM
05/31/15 11:47 AM
Posts: 16,210 Mesa, Arizona
dart4forte
Mesa, Arizona
Ok, Latest subject. Let's talk 1968-1972 340 fan blades. Please show pics of your original fan blades and part#s (please be specific as to what year yours is when posting). Keep in mind that only 100% known originals to the engine being studied are what's helpful here.
Here is one off my survivor 1971 340 engine. It's got a "215" blade. The trick will be replicating the part number. My part number along with the pen taster is stamped into my blade.
Abe Lincoln
#1837934
05/31/15 12:04 PM
05/31/15 12:04 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The trick will be replicating the part number. My part number along with the pen taster is stamped into my blade. Do you mean replicating the ink stamp when a fan is being restored? If so there are ink stamps made for that now (as well as the "Engine Side" stamps) I've also got my own in the works because I'm not happy with the accuracy of the current versions. The part#'s being stamped into each of the blades vs the ink stamped versions (and a 3rd version with just a small pentastar and number without the full part#) was a variable depending on when your car was built. I think more info. is needed on this topic concerning which is right for which application, year, etc.
#1838244
05/31/15 08:42 PM
05/31/15 08:42 PM
dart4forte
Mesa, Arizona
The trick will be replicating the part number. My part number along with the pen taster is stamped into my blade. Do you mean replicating the ink stamp when a fan is being restored? If so there are ink stamps made for that now (as well as the "Engine Side" stamps) I've also got my own in the works because I'm not happy with the accuracy of the current versions. The part#'s being stamped into each of the blades vs the ink stamped versions (and a 3rd version with just a small pentastar and number without the full part#) was a variable depending on when your car was built. I think more info. is needed on this topic concerning which is right for which application, year, etc. That's makes it easy
Abe Lincoln
