Re: WHAT IS THE TOOL TO SET PINION ANGLES
[Re: B G Racing]
#1618504
05/15/14 04:18 PM
05/15/14 04:18 PM
Posts: 11,484 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2° trans down and 2° pinion up is parallel and the relative pinion angle would be 0° under load...Not 2° nose up which is what I think some of these guys are interpreting it as...drive shaft angle is irrelevant as u-joint angle will be equal and opposite at both joints.
If you lower the trans yoke by lowering the front of the car or put a big tire on it and raise the rear end up into the chassis, the pinion angle (difference between driveshaft and pinion angles) will quickly go positive at some point, if parallel is the only thing taken into consideration. Imagine moving the centerline of one of the yokes up or down while the other remains stationary. What will that do to the operating angles, parallel or not?
I agree, having the trans and pinion centerlines parallel or close to it is beneficial and can be accomplished with engine/trans location. However, pinion angle, the relationship between the d-shaft and the pinion, has to remain correct according to the type of suspension and never go positive. It is a setting, not an adjustment.
It's not that one's right and one's wrong. Both matter, but one is most important and has to be right.
[Re: Monte_Smith]
#1618505
05/15/14 07:53 PM
05/15/14 07:53 PM
Quicktree
There are two sides and this will never change and it seems pretty damn obvious that both work.........which means........in the REAL world, it doesn't really make much of a difference.
Monte
you finally figured it out
[Re: Quicktree]
#1618506
05/15/14 09:04 PM
05/15/14 09:04 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Monte
Oh, it will change alright.
Dont like to say never. Its a 20 year side project of mine to get it to change. Only 10 years into it though.
