426 Hemi World Block #1617501
05/07/14 09:08 PM
05/07/14 09:08 PM
Alberta, Canada eh!
70Cudha Offline OP
70Cudha  Offline OP
Alberta, Canada eh!
I would like to mount a Saginaw power steering pump to my Mopar Performance 426 reproduction World hemi block but my big block rear bracket and pump mounting stud will not clear the block. Who sells a bracket that will mate the pump to this block?
Also, I'm looking for a throttle cable bracket and throttle return spring bracket for this same engine.
Thx in advance.
Kim
1970 EV2 Barracuda Hardtop
1970 FE5 Barracuda Gran Coupe Convertible
1969 B5 Dart GTS 383
1968 TT1 Barracuda Convertible
1997 Ram SS/T
2008 3500 Ram Diesel
Re: 426 Hemi World Block [Re: 70Cudha] #1617502
05/07/14 09:58 PM
05/07/14 09:58 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Re: 426 Hemi World Block [Re: pattyboy 572] #1617503
05/08/14 01:09 AM
05/08/14 01:09 AM
Alberta, Canada eh!
70Cudha Offline OP
70Cudha  Offline OP
Alberta, Canada eh!
I'll check them out
1997 Ram SS/T
Re: 426 Hemi World Block [Re: 70Cudha] #1617504
05/08/14 11:50 AM
05/08/14 11:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What exactly is not clearing and where ? A picture would be nice too.
Plan on doing some grinding , I really doubt you are going to find a specialized bracket to clear a short production run RACE block.
But I've been wrong before
Re: 426 Hemi World Block [Re: JohnRR] #1617505
05/08/14 02:40 PM
05/08/14 02:40 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you're talking about this style pump all I had to do on mine was change out the long stud on the back of the pump for a regular bolt so it would clear.
You don't get full travel on the adjustment slot but there's more than enough to adjust the belt.
Re: 426 Hemi World Block [Re: pattyboy 572] #1617506
05/08/14 06:11 PM
05/08/14 06:11 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
try these guys the best... http://bouchillonperformance.com/bpe_home
I bought all the brackets & pulleys for my front end from them everything fit fine. I'm running the saginaw on a world block stage V replacement heads hemi damper 440 style pulleys.
Re: 426 Hemi World Block [Re: SNK-EYZ] #1617507
05/09/14 10:31 PM
05/09/14 10:31 PM
Alberta, Canada eh!
70Cudha Offline OP
70Cudha  Offline OP
Alberta, Canada eh!
I spoke with Randy and after trading some info and pics with each other it was determined that I will have to shorten the one stud as well. Thx all!
1997 Ram SS/T
