Mopar Performance Cast Covers Leak #1617270
05/06/14 10:50 PM
05/06/14 10:50 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
I have been doing so searching, it appears that this is a very common problem. Back driver side on mine is leaking. I was using rubber coated cork.
From the searching it appears that Mr Gasket Ultras might be the ticket? Anything better these days?
I am going to make sure they are not hitting on anything (383 with 906 heads and RPM intake). But I don't think they are. They rock on the head without a gasket.
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Mopar Performance Cast Covers Leak [Re: Crazy68Dart] #1617271
05/06/14 11:03 PM
05/06/14 11:03 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Iv had 1 SB set and 2 BB sets. Never had a single leak..
I am truckless..
Re: Mopar Performance Cast Covers Leak [Re: Crazy68Dart] #1617272
05/06/14 11:35 PM
05/06/14 11:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Got a set of 'hi-temp' gaskets under cast covers...
They have been leak-free for a lot of years...
Re: Mopar Performance Cast Covers Leak [Re: RSNOMO] #1617273
05/06/14 11:40 PM
05/06/14 11:40 PM
Canton, Ohio
Canton, Ohio
Have a P/N? Thanks!
Re: Mopar Performance Cast Covers Leak [Re: Crazy68Dart] #1617274
05/07/14 12:21 AM
05/07/14 12:21 AM
IN
ahy Offline
ahy  Offline
IN
I have the MP covers and have had the best luck with Felpro standard cork/rubber. I have the super thick ones on now... they stopped leaking after I re-torqued (gently) for about the 3'rd time. Not a fan of the super thick gaskets.
Re: Mopar Performance Cast Covers Leak [Re: ahy] #1617275
05/07/14 12:48 AM
05/07/14 12:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kid put his on the 413 about 4 years ago.Used the Mr Gasket Ultras.No leaks.They are the only gaskets we run.Ive had covers off a few times and they still seal.We use there header gaskets also with great results.Rocky
Chrysler Firepower
Re: Mopar Performance Cast Covers Leak [Re: therocks] #1617276
05/07/14 12:57 AM
05/07/14 12:57 AM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
Check with board member Greg - fantastic gaskets
http://www.superformanceproducts.com/
Re: Mopar Performance Cast Covers Leak [Re: max_maniac] #1617277
05/07/14 01:49 AM
05/07/14 01:49 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I siliconed the gasket to the valve cover, but not to the head.
Re: Mopar Performance Cast Covers Leak [Re: DaytonaTurbo] #1617278
05/07/14 09:18 AM
05/07/14 09:18 AM
Canton, Ohio
Canton, Ohio
I have a set of Mr Gasket Ultras on the way (thanks Jegs!).
I am going to glue them to the cover, but not the head. Hopefully they are thick enough to seal without having to crank down on the valve cover too much and risk cracking it.
If I can't get them to seal I'll probably go back to a set of stamped steel covers that will better contour to the imperfections on the head mating surface.
Re: Mopar Performance Cast Covers Leak [Re: Crazy68Dart] #1617279
05/07/14 10:01 AM
05/07/14 10:01 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
There is no magic gasket for bad components however, when those gaskets wear out you may want to give these a try.
We are local to you also
https://board.moparts.org/ubbthreads/show...e=2#Post7855502
Re: Mopar Performance Cast Covers Leak [Re: DaytonaTurbo] #1617280
05/07/14 10:26 AM
05/07/14 10:26 AM
Georgia
Steve Bryant Offline
Georgia
Once while I was working on the rockers, I had a leak with my MP Covers and a 440. What I did was use a VERY THIN coating of high-temp ATV on the covers to hold the gasket in place. Once it was dried, I fitted it onto the heads and lightly tightened it.
Ever since then can remove the covers and replace them and have experienced no leaks.
I would get a new set of rubber gaskets and try that.
Re: Mopar Performance Cast Covers Leak [Re: Steve Bryant] #1617281
05/07/14 12:54 PM
05/07/14 12:54 PM
dogdays Offline
dogdays  Offline
So what's a hi-temp ATV? Honda? Polaris?
No worries, I know you meant to say RTV...
R.
Re: Mopar Performance Cast Covers Leak [Re: dogdays] #1617282
05/07/14 01:13 PM
05/07/14 01:13 PM
California, U.S.A.
Torquemonster440 Offline
California, U.S.A.
I run M/T cast covers on my 440.What helped me was switching to valve cover studs instead of bolts. The studs help align everything much easier... (no more fishing around for the hole in the back corner). Torque to 30 inch lbs. No leaks.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Mopar Performance Cast Covers Leak [Re: max_maniac] #1617283
05/07/14 11:48 PM
05/07/14 11:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Best gaskets money can buy and he's only 15 minutes away
Andy all you had to do was give Greg a call and you would have the "good gaskets"
Gus
64 Plymouth Savoy
Dana 60
Re: Mopar Performance Cast Covers Leak [Re: fourgearsavoy] #1617284
05/07/14 11:59 PM
05/07/14 11:59 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I just switched from my chrome valve covers to the MP Polished cast aluminum valve covers and used the felpro 1612 high temp gaskets. I used Felpro Right Stuff to glue them to the valve cover and so far no leaks. I also used the bolts instead of studs on my covers.
http://www.summitracing.com/parts/fel-1612
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Mopar Performance Cast Covers Leak [Re: 70sixpkrt] #1617285
05/08/14 04:22 AM
05/08/14 04:22 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Moroso rubber over steel ,no sealer and never a leak.Stamped covers, cast or fabbed.Stock cyl heads or aftermarket with a machined rail.Expensive as the best usually is.
Leave the gun.......take the Cannoli's....Mike
Re: Mopar Performance Cast Covers Leak [Re: DaytonaTurbo] #1617286
05/08/14 08:53 AM
05/08/14 08:53 AM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
That's what I did too. No leaks and I had my covers on and off all the time due to adjusting the valve lash on mechanical cam.
Re: Mopar Performance Cast Covers Leak [Re: dogdays] #1617287
05/08/14 09:00 AM
05/08/14 09:00 AM
Georgia
Georgia
DOOH! Yes, RTV!
Re: Mopar Performance Cast Covers Leak [Re: Crazy68Dart] #1617288
05/08/14 01:59 PM
05/08/14 01:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
How bad do they rock? If the flange is flat you can lap it on a flat surface using sandpaper to straighten it out a bit.
- Stu Harmon
Re: Mopar Performance Cast Covers Leak [Re: mike s] #1617289
05/08/14 02:06 PM
05/08/14 02:06 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
This.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
