Re: Mopar Performance Cast Covers Leak [Re: OhioMopar] #1617290
05/09/14 07:27 PM
05/09/14 07:27 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
The issue is the head. The rail is not straight. I put a straight edge across it and it is off by quite a bit.
I ended up double stacking the new gaskets. I am not thrilled the the setup, but it is not leaking. The Mr Gasket Ultra Seal gaskets are pretty thin, not too impressed with them in that regard. If someone sells a thicker gasket I would like to try a single thick gasket.
Engine compartment is coming together, still more work and cleanup to do. Starts right up, fuel system is working (sumped stock tank, new lines, and RacePump mechanical pump, regulator, etc.).
383, Hemi 4-Speed, AlterKtion, D60
Re: Mopar Performance Cast Covers Leak [Re: Crazy68Dart] #1617291
05/09/14 08:02 PM
05/09/14 08:02 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
With factory heads and cast covers I,ve had good luck with these gaskets from sce , they are 1/4 " thick.
http://scegaskets.com/product/sce-gaskets-part-number-264076/
Hylomar or permatex #2 on the cover side
Re: Mopar Performance Cast Covers Leak [Re: ChinooK440] #1617292
05/09/14 08:39 PM
05/09/14 08:39 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
The Felpro 1612 are .172 thick.
http://www.summitracing.com/parts/fel-1612
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
