440 rear main seal #1617122
05/06/14 05:11 PM
05/06/14 05:11 PM
bigfork mn
dragram440 Offline OP
bigfork mn
So I have been racing my car with a drip from the rear main seal or retainer or possibly the oil pan gaskets, So last weekend I put a Mancini retainer and seal in and new good oil pan gaskets and we took it out for a few test pulls and get it back in the shop and it still has a couple drips hanging off the bell. I just cant see with how nice it all went together that it could possibly leak. Now I am thinking it has to much crank case pressure. I have a big k&N breather on each valve cover and no pcv. Would a crank case evac to the headers fix this drip?
67' charger 499 RB 10.57 at 127
Re: 440 rear main seal [Re: dragram440] #1617123
05/07/14 01:27 PM
05/07/14 01:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you positive it's the rear main seal ? Cam plug and main galley plugs in there , valve covers , head gasket , intake valley , oil pressure ports above ...
Re: 440 rear main seal [Re: dragram440] #1617124
05/07/14 01:34 PM
05/07/14 01:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you run a full exhaust I would say dont bother
with the exhaust style evac... greater than 5"hg back
pressure will cause the exhaust to back up, burn out
the check valve and start pressurizing the crank case
Re: 440 rear main seal [Re: MR_P_BODY] #1617125
05/07/14 02:12 PM
05/07/14 02:12 PM
bigfork mn
bigfork mn
Its definately not coming out from up top. It either has to be the rear seal , retainer, or oil pan gaskets, Unless it is coming out of the cam plug or a oil galley plug. I might pull the tranny out this weekend and see if I can see anything on the back of the block. I have 3" exhaust with Dynomax Bullets and turns out in front of the tires so I would think it would pull enough vacuum. Do those evac kits seem to help?
Re: 440 rear main seal [Re: dragram440] #1617126
05/07/14 02:18 PM
05/07/14 02:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hook up a combo gauge to the back of your valve cover
and see what you have going on
Re: 440 rear main seal [Re: dragram440] #1617127
05/09/14 07:46 AM
05/09/14 07:46 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Are you certain that you have the 2 pan bolts that screw into the seal retainer shorter than the other 18 bolts. Some of these dopes(mr gasket for one) will ship you in their pan bolt set, all 20 the same length. When torquing bolts into the retainer they will bottom out before pan gasket is cinched and you cannot see this if engine is in car when installing pan.
As flywheel cover tucks up over pan at rear, a pan leak will appear to be rear main leaking.
Take two 5/16 x 18 pitch 1 and 1/2 long grade 8 bolts, cut off heads with a dremel tool making studs. Use these with nylock nuts and lock washers as retainer pan bolts.
I posted a very long thread on my recent misadventure on all this a few weeks ago when I installed the Mancini retainer and a Road Race pan.
If you already aware of shorter bolt requirement at retainer,please excuse me for butting in.
As an aside, the first retainer that Mancini had sent me was mis-drilled and the pan bolt holes were more shallow than they should have been which made my initial leakage even more severe.
All is well now, but was a real pain getting there.
Re: 440 rear main seal [Re: Sxrxrnr] #1617128
05/09/14 07:55 AM
05/09/14 07:55 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Here is link to my rear main and/or oil pan leakage saga and all that I learned in resolving it.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: 440 rear main seal [Re: Sxrxrnr] #1617129
05/09/14 06:45 PM
05/09/14 06:45 PM
bigfork mn
bigfork mn
I have studs in everything so I dont think that is the issue. I will definately double check it this weekend just to make sure.
Re: 440 rear main seal [Re: dragram440] #1617130
05/09/14 07:29 PM
05/09/14 07:29 PM
smyrna,tn
draginmopars Offline
smyrna,tn
I have a slight rear oil leak to deal with
Due to running a girdle and studded oil pan.
My plan is to check for the leak,
using a fluorscent leak detector dye,
maybe won't have to pull the engine
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: 440 rear main seal [Re: draginmopars] #1617131
05/13/14 03:36 PM
05/13/14 03:36 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I was running the Mancini retainer on my 512 and pulled it twice to re seal. The last time I found that the seal retainer was hitting the nuts on the #5 main cap thus preventing it from fully seating. Changed to a stock type retainer and no more leaks. I could've also ground a couple of grooves in the Mancini retainer enough to clear the nuts on the studs.
Re: 440 rear main seal [Re: Hemi_Ram] #1617132
05/14/14 01:01 PM
05/14/14 01:01 PM
bigfork mn
bigfork mn
I have ARP main studs and the cap seemed to clear the nuts just fine. I looked pretty close to make sure because someone else had mentioned that. I had it apart again last weekend and also put a crank case evac kit on it and took it out for some test runs and still has a few drips off the bottom of the bell. Its not a horrible leak its just one that will drive me crazy. I just want it dry!
