Re: Initial hard to crank over but then turns over good...?
[Re: TheOtherDodge]
#1616406
05/06/14 04:05 PM
05/06/14 04:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since I drove the truck to work today (since it is a street truck, 22 miles from work to home), I went out to get a video of it. It started like a champ! I had the battery on a charger last night so I am begining to wonder if I need a stronger battery or alternator?
You should check the cranking power of the battery.. load test... whats the output of the alt ![](/ubbthreads/images/graemlins/wave.gif)
[Re: TheOtherDodge]
#1616407
05/06/14 04:09 PM
05/06/14 04:09 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a stock one wire 60 amp chevy alternator on my Duster and it will keep up on MOST race days but i usually don't go a lot of rounds like some guys. About every other week i have to charge it during the week or it will drop to a voltage level where the alternator isn't energized enough to charge the battery and actually starts discharging it.
