37 Plymouth coupe heat help #1615227
05/02/14 09:55 PM
05/02/14 09:55 PM
Ohio
E
eddie27 Offline OP
eddie27  Offline OP
E
Ohio
I bought a 37 coupe that I am fixing a few odds and ends on before I give it to my father. I have gone thru the heater and the got everything connected. The hose that is connected is fine but I can't figure out where the other end goes. Probably easy for you guys but i am stumped.
Re: 37 Plymouth coupe heat help [Re: eddie27] #1615228
05/02/14 09:57 PM
05/02/14 09:57 PM
Ohio
E
eddie27 Offline OP
eddie27  Offline OP
E
Ohio
You can see where the other hose would hook up at the firewall but there is no connection that I can find for the other end of the hose.
Re: 37 Plymouth coupe heat help [Re: eddie27] #1615229
05/03/14 04:11 AM
05/03/14 04:11 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
If one hose is connected at the back of the head, the other needs to be connected at, near, or to the water pump. Is there a pipe plug somewhere around there?
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: 37 Plymouth coupe heat help [Re: shinnery] #1615230
05/03/14 10:11 AM
05/03/14 10:11 AM
Ohio
E
eddie27 Offline OP
eddie27  Offline OP
E
Ohio
Really crawled up in there and up underneath that short piece of rubber hose is a plug. Off to see if I can find an inlet tube. Thanks Bryce.
