Does altitude effect spark plug choice?
#1614964
05/02/14 02:16 AM
05/02/14 02:16 AM
Posts: 733 Nampa, ID
MadMatt
Nampa, ID
I'm doing my first tune up on my Dart since I moved from about 500 ft. above sea level to my current 2600 ft. above sea level. Would this change what I should select for a heat range? My motor is a 364 ci SB with ported 308 iron heads, about 9.75:1 compression, full length headers and Comp Cams hydraulic cam, and MSD 6AL with Blaster coil. I've been running Autolites or NGKs gapped at .050. Anybody have any specific suggestions?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Does altitude effect spark plug choice?
[Re: MadMatt]
#1614965
05/02/14 02:34 AM
05/02/14 02:34 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
No, but you do need to address the carb jetting and possibly the timing.
I am truckless..
[Re: MadMatt]
#1614967
05/02/14 02:45 AM
05/02/14 02:45 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Nope, will probally induce spark knock..
I am truckless..
[Re: MadMatt]
#1614970
05/02/14 11:50 AM
05/02/14 11:50 AM
RapidRobert
As said with the thinner air drastically lowering the density which is going to change cyl psi/pinging point I would retune the dist/carb. Get the carb reasonably close (A/F ratios) then fine tune the timing: initial/same total (if correct now)/springs/vac adv. then fine tune the carb a bit more as needed. (1) staying just under the pinging point (2) correct or near correct A/F ratios
