Re: Modern Bullitt build
[Re: Keepat]
#2882584
01/31/21 09:03 PM
01/31/21 09:03 PM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Windshield trim install with no problems other than sore palms;-) Pat
I found that if you use a plastic trim stick and get behind each clip and flex the clips pretty good it will allow the trim to go in a whole lot easier.
[Re: Keepat]
#2883035
02/02/21 10:24 AM
02/02/21 10:24 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Are you keeping it or selling it when its done? Keeper! Congrats if you are, any level build/documented like this tends to be on the auction block 2 weeks after completion. Can't wait to see it when its done, gorgeous car.
[Re: mopar4don]
#2888894
02/15/21 07:29 PM
02/15/21 07:29 PM
Posts: 676 Maryland
Keepat
Maryland
Wow, now that is some art work! Beautiful Pat Thanks Don! I think this is the closest I’ll ever get to metal sculpture;-) Pat
[Re: Greenwood]
#2890354
02/19/21 08:01 AM
02/19/21 08:01 AM
Posts: 676 Maryland
Keepat
Maryland
A question/comment. Is there a reason you went with an X-pipe over an H-pipe crossover? My own ear likes the more "classical" sound of the H-pipe. Can't wait to see you take it for the first drive, though. Going with the X pipe will make for a much cleaner installation of the exhaust cut outs as I can install them right at the first curve aft of the headers. After over six years I am so looking forward to driving this car down the road! Thanks Pat
[Re: ek3]
#2890355
02/19/21 08:03 AM
02/19/21 08:03 AM
Posts: 676 Maryland
Keepat
Maryland
this will be to nice to ever see the streets ! very nice. outstanding work..... Won’t make it this year but be sure this car will go on the hotrod power tour in 2022. Thanks Pat
[Re: MadMopars]
#2892981
02/25/21 11:05 AM
02/25/21 11:05 AM
Posts: 676 Maryland
Keepat
Maryland
Beautiful work, as always! That being said, when are you going to get that roller rear end out of there and get the Dana installed? Maybe we should put a Dana in my son’s 68 Mustang to balance things out;-) Thank you! Pat
[Re: larry4406]
#2894594
03/01/21 10:10 PM
03/01/21 10:10 PM
Posts: 676 Maryland
Keepat
Maryland
Pat your craftsmanship and attention to detail is amazing!
I hope to see this car one day.
-larry Thanks Larry! It will be at Carlisle this summer! Pat
[Re: Keepat]
#2894657
03/02/21 06:50 AM
03/02/21 06:50 AM
Posts: 519 Virginia
larry4406
Virginia
-larry Thanks Larry! It will be at Carlisle this summer! Pat Thanks Pat - I hope to make it this year!
