Positive battery cable #1614674
05/01/14 06:43 PM
05/01/14 06:43 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
There's a guy over on FABO selling repro E-body positive battery cables. He says they fit and work fine on A-bodies. I thought my 68's cable was a lot longer. Has anyone used the E-body cables on their 67-69 A? The E-body cables are dirt cheap...A-body cables not so much.
Re: Positive battery cable [Re: burdar] #1614675
05/01/14 09:12 PM
05/01/14 09:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I sold several of them for the A body guys and never heard of any issues .
But you want one for the small block E body to use on a small block A body (small block cable is longer)
ck mopar number 3764166 ( replaces 2983648 )
pt # 2983649 is big block E body cable,, but it's about 5-6 inches shorter
Re: Positive battery cable [Re: burdar] #1614676
05/01/14 09:15 PM
05/01/14 09:15 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
an E body cable will work but because it is 6 or 7 inches shorter it will "drape" to the inner fender towards the firewall rather than follow tight to the battery
Re: Positive battery cable [Re: gtx6970] #1614677
05/01/14 09:43 PM
05/01/14 09:43 PM
London Ontario Canada
SYDWAZ Offline
SYDWAZ  Offline
Is the E-body positive cable for a SB still available from chrysler.
Re: Positive battery cable [Re: SYDWAZ] #1614678
05/01/14 10:44 PM
05/01/14 10:44 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I think that's what he's selling. I bought one for my Challenger from the dealer. That was three years ago at least.
Re: Positive battery cable [Re: SYDWAZ] #1614679
05/01/14 11:25 PM
05/01/14 11:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It was when I ck'd last. Last tiem I ck'd retail was les than $50 for the positive cable.
Negative ( pt # 2983778) was almost $70
But thats probably been a year ago.
But judging by how many are all over ebay,,,I'm gonna say yes.
Re: Positive battery cable [Re: gtx6970] #1614680
05/01/14 11:58 PM
05/01/14 11:58 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
My dealer contact just found that part# you listed Bill...thanks. It lists for $34.35.
