Re: Need a Quieter Muffler - Please Help
[Re: YO7_A66]
#1614652
05/02/14 10:50 AM
05/02/14 10:50 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
This is how member DAVENC mounted his second muffler in the above reference. ![](/ubbthreads/images/graemlins/thumbs.gif) If is a Magnaflow 7x14 piece. I will be using this idea when I change my exhaust system this Summer.
I don't think I could wedge in the 7" mufflers beside my tank comfortably but I could do the 4" ones for sure.
If I do add these, I am assuming the longer (12" vs 22") the better or not? Also, where would you want to place them to get the best drone elimination? In other words, close as possible to the Flowmasters or closer to the tips?
I want to make sure I do this right and don't shred my exhaust system playing around with this. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: cjskotni]
#1614653
05/02/14 10:56 AM
05/02/14 10:56 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""I am assuming the longer (12" vs 22") the better or not?"" You want to try and add the largest (diameter & length) muffler that you can fit into the space. Magnaflow makes 4", 5", 6", and 7" diameter mufflers for that location. http://www.magnaflow.com/02product/02muffler.asp
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1614655
05/02/14 12:33 PM
05/02/14 12:33 PM
cjskotni
North Carolina
Would using a resonator as opposed to a glasspack make more sense? Isn't that what resonators are for? Which would be a better way to go as they are both about the same size/shape/price??
[Re: cjskotni]
#1614656
05/02/14 02:08 PM
05/02/14 02:08 PM
YO7_A66
Indiana
I was confused in the terminology so I asked a Magnaflow Tech to tell me the difference between a muffler and a resonator. This was his answer: ""Mufflers and resonators are one in the same. We use the term resonator when two mufflers are used in line of one another."
When I pulled the original style resonators off of my Challenger, I was surprised to see a "straight thru" design. It was an oval shape so it would have more noise suppression than a glass pack type (round) style of muffler in that location.
The round straight-thru mufflers will not have as much noise suppression as the round "chambered" style. The chambered style will be more restrictive than the straight-thru style. So it depends on what you are after. The space that you are wanting to add a muffler is very restrictive, so a round muffler is about your only choice.
I have read that when trying to stop a droning noise, a second muffler (resonator) is used to break up the sound waves. Adding the second muffler will also change the sound depending on the selection of muffler. If you want to change the sound of the exhaust a lot, then you may want to start over with your existing muffler selection. If you want to quiet down the exhaust a little bit, then adding the second muffler may do that. Then the type of muffler will then determine the final loudness and the performance level.
It appears that you might end up with two mufflers per side due to the size of the exhaust, the size of the engine, and you do not want to lose performance.
[Re: cjskotni]
#1614660
05/02/14 11:23 PM
05/02/14 11:23 PM
Posts: 1,176 Crockett ,TX
98RAM1500
Crockett ,TX
yeah those are the 18's, just remember that it will make the overall exhaust sound alittle quieter aswell.
[Re: YO7_A66]
#1614662
05/03/14 02:13 AM
05/03/14 02:13 AM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
If the Magnaflow tech said mufflers & resonators are the same thing, that could be true sometimes, but also not true a bunch of the time. If you were going to run a muffler & a resonator in the same system or bank, the muffler would not need to be straight-through, but resonators are always straight-through. Resonators should not add more restriction to a system. You could use Ultra Flows as resonators, glasspacks, Corsa, etc. - as long as they are straight-through. Beware though, many glasspacks downsize internally & that will build backpressure. On your Charger exhaust, you'll have room for 18" long body & 4" diameter - maybe a little larger diameter. On the noise control package from the factory on these cars, the resonators were 4" round & the bazooka tips connected directly to them via sheetmetal screws. I did a very similar setup on my '73 Rallye 340 car using Walker 4" round mufflers - see photo.
[Re: Sunroofcuda]
#1614663
05/03/14 10:47 PM
05/03/14 10:47 PM
cjskotni
North Carolina
Ok guys, I went ahead and ordered the 18" Magnaflows. I may not get them on now as your picture just reminded me that I need to get a set of the bazooka tips for my Charger and that will dictate where the Magnaflows need to go exactly. When I have some spare money and this car is running somewhat reliably, I will get these so I can have everything put together at once the right way. Thanks guys! I am hoping this will kill the drone and quiet down this exhaust somewhat. ![](/ubbthreads/images/graemlins/luck.gif)
[Re: cjskotni]
#1614664
05/03/14 10:53 PM
05/03/14 10:53 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Not sure what kind of power you are making.. could consider going to a 2.5 or 2.75" tail pipe. That will help too.
383, Hemi 4-Speed, AlterKtion, D60
[Re: hemidart1]
#1614666
05/21/14 02:40 PM
05/21/14 02:40 PM
Posts: 4,590 Motor City
6PKRTSE
Motor City
I have 40 series Flowbastards on my Charger also & got sick of the resonation while driving. I added the 18" Dynomax glass packs to the tail pipes like the factry resonators & man what a difference. So much quieter, no more resonating & my ears don't ring for hours after driving it for awhile now. Wish I would have done it years ago now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1614667
05/24/14 07:06 PM
05/24/14 07:06 PM
cjskotni
North Carolina
Thanks for the reply! I have a set of the 18" Magnaflow glass packs and tips to get put on when I have the time to take her in to the exhaust shop. I am hoping I will have similar results! ![](/ubbthreads/images/graemlins/thumbs.gif)
