Re: "Custom 33"
[Re: Matt Erich]
#1613491
06/28/14 02:10 PM
06/28/14 02:10 PM
Posts: 7,506 Az
Crizila
Az
4 link mocked up on my chassis.
Fastest 300
Re: "Custom 33"
[Re: Crizila]
#1613492
07/10/14 10:50 PM
07/10/14 10:50 PM
Posts: 7,506 Az
Crizila
Az
Old school tires and wheels going on my 33.
Fastest 300
Re: "Custom 33"
[Re: Crizila]
#1613493
09/02/14 05:35 AM
09/02/14 05:35 AM
Posts: 7,506 Az
Crizila
Az
X-mas came early this year.
Fastest 300
Re: "Custom 33"
[Re: Crizila]
#1613497
09/03/14 12:51 AM
09/03/14 12:51 AM
moparpollack
Lil Herman
Lil Herman
85086
Looks like fun, wiring a fiberglass car has its challenges DAMHIK. ![](/ubbthreads/images/graemlins/fan.gif)
Re: "Custom 33"
[Re: Crizila]
#1613502
09/09/14 07:21 PM
09/09/14 07:21 PM
Posts: 60 IN
Matt Erich
IN
Thanks for the pictures John! Its always fun watching customer builds in the process and from looking at your previous builds I am sure the 33 is going to turn out great!
The ground problem will likely be very minimal as we have full 1/4 thick steel floors and interior caging that bolts directly to the frame. This should make finding a solid ground easy and quick.
Good luck on the build and like I have always said call anytime!!!!!!!
Matt
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
Re: "Custom 33"
[Re: moparx]
#1613507
09/11/14 01:46 AM
09/11/14 01:46 AM
Posts: 60 IN
Matt Erich
IN
When I started designing this car and looking at what target market I wanted to focus on I made my mind up that it would be a driver. I am not saying the body and chassis combo cant be a trailer queen!
I built the car for the road and took safety into consideration in every part of the car. Could I of went with thin wall round tubing, 1/2 inch cross member instead of 3/4, 1/2 heims and rodends instead of 3/4, fiberglass floor with a thin piece of wood sandwiched between the glass instead of 1/4 steel???? Sure I could of and it would of saved me THOUSANDS of dollars and I probably would of sold the same number of cars I have to date. BUT I wanted to design a unique street rod for an untapped mopar market that if a husband and wife wanted to jump in and drive across the country they wouldn't be worried about a deer jumping out and going completely threw the car!
The car is fiberglass not steel I understand that so I have made up for the weakness in panels by supporting the structure around it. I am sure John will post pictures of the steel interior and the chassis bracing. I hope to be updating the website soon with new pictures of the latest designs.
Cheers, Matt Custom33
Re: "Custom 33"
[Re: dogdays]
#1613509
09/12/14 12:13 AM
09/12/14 12:13 AM
Posts: 10,656 Freeport IL USA
poorboy
Freeport IL USA
Well, putting unnecessary weight in it with really thick steel sections is a lot different than using heavy duty suspension components. The problem for me is that I look at a 1/4" plate just sitting there and know that most of it isn't doing anything. Metal that's close to or on the neutral axis is just along for the ride.
You don't have to be Anthony Colin Bruce Chapman, but economy doesn't have to mean cheap.
R.
Actually, if the glass body has a steel structure, and the 1/4" plate is tied into that structure, having 1/4" plate at body to frame mounting points will make a tough glass body.
For many body/frame chassis vehicles, the body and frame often separate in crashes. Usually the bolts pull through the frame mount or through the body structure. With a 1/4" 2" x 4" tube frame, and a 1/4" plate sandwiched between the glass, the body/frame would probably stay together, which is usually helpful for the passengers.
Sounds like he put some thought concerning occupant safety into building the car, which is more then a lot of companies have done over the years. And I don't have a dog in this fight. Gene
