Transgo or B&M shift kit #1613423
04/29/14 01:15 PM
04/29/14 01:15 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
Any opinions out there in which one is better for a small block 727? One trans builder this morning told me the Transgo was not good, (something about how it makes the tire or trans momentarily bind or lock up on 1-2 shift?).
This is for a street run 340.
Anyway, any experience out there?
Re: Transgo or B&M shift kit [Re: dd340] #1613424
04/29/14 01:50 PM
04/29/14 01:50 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
My trans guy used the B&M kit when he built my trans some years back. I supplied the kit. When I picked it up he commented that he had never used the B&M kit in the past but he liked it and planned to use them going forward. I'm very happy with the results.
Re: Transgo or B&M shift kit [Re: dd340] #1613425
04/29/14 02:17 PM
04/29/14 02:17 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Transgo is a good kit,the builder claiming it locks up on shifts is one i wouldnt let anywhere near my car. for what its worth i never let anyone else build my transmissions,they are pretty darn simple things.
Re: Transgo or B&M shift kit [Re: 1Fast340] #1613426
04/29/14 02:22 PM
04/29/14 02:22 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
It is a pretty well known builder and he advertises in most of the mopar mags, that is why I took him seriously.
Re: Transgo or B&M shift kit [Re: dd340] #1613427
04/29/14 03:40 PM
04/29/14 03:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TransGo TF-2 kit has provisions that minimize the 1-2 shift overlap as does the B&M Transpack. The cheaper "plate kits" actually exacerbate bindup on manual upshifts.
If your builder is observing the 1-2 bindup on jackstands it isn't the same when under power.
Re: Transgo or B&M shift kit [Re: dd340] #1613428
04/29/14 03:49 PM
04/29/14 03:49 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Been using trans go kits for almost 40 years, Nuff said
Re: Transgo or B&M shift kit [Re: John_Kunkel] #1613429
04/29/14 03:57 PM
04/29/14 03:57 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
thanks for jumping in John, that was exactly what he mentioned about when up on a lift you can see the bind up. I take it from your response that this isn't really a problem?
Re: Transgo or B&M shift kit [Re: dd340] #1613430
04/29/14 03:59 PM
04/29/14 03:59 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
BTW, he isn't my builder, I was just calling this company for the parts to complete the rebuild and he mentioned this "bind up" issue on the phone
Re: Transgo or B&M shift kit [Re: dd340] #1613431
04/29/14 08:44 PM
04/29/14 08:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
At the risk of becoming a bore, I'll repeat what I've said several times...jackstands is the absolute worst place to judge the performance of a transmission.
It's impossible to remove all of the overlap on a manual 1-2 upshift but a good kit like the TF-2 goes a long way towards it.
