Re: Remflex exhaust gaskets
[Re: floridian]
#1613054
04/28/14 04:06 PM
04/28/14 04:06 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Kinda curious here, are these just darn good gaskets or more of a fix for warped manifolds?? they are certainly unique.. Any thoughts about this on here??
I guess I should add here that I installed one side on my 440 and found them really different, the reason for my post here... Both sides have blown at one cylinder, using the gaskets that came with the original gasket kit, and I hope these last longer..
[Re: floridian]
#1613055
04/28/14 07:50 PM
04/28/14 07:50 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I have the exhaust manifold gaskets but havent installed them yet...I can attest to the 2.5" 3-bolt flange gaskets though....they SEAL and they do a great job at it too...I have 6 sets on my system and not one leaks...but it is dependent on the flanges you have...I have 1/2" stainless on each side sandwiching the RemFlex
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: SANDYinNS Canada]
#1613058
04/29/14 01:46 AM
04/29/14 01:46 AM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
They work very well where other gaskets fail. I started using them on all of my inline 6 applications. Slats are notoriously hard to seal up sometimes it goes well other times....I use remflex now for the all zero problems since!
The best exhaust gaskets I've ever used!
[Re: 70Duster440]
#1613064
05/02/14 12:01 AM
05/02/14 12:01 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
I used them to mate early 340 exhaust manifolds to Magnum heads. A bit of a mismatch at the floor of the port, not much shared sealing area between the 2 designs. Remflex sealed them together fine!
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
