Re: help me pick a tranny cooler
[Re: ffej]
#1612134
04/26/14 12:40 AM
04/26/14 12:40 AM
RapidRobert
I hear the "stacked plate" types are the most efficient but to k.i.s.s. I'd get the largest regular type one that will fit in front of your radiator fins & you'l be fine if you get a large one & I plumb the hot fluid in to the top of the cooler just like hot coolant goes to the top of the radiator. A bit picky but that's me
[Re: Cab_Burge]
#1612137
04/26/14 01:07 PM
04/26/14 01:07 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I used one out of a ford super duty truck.. They are large and have mounting brackets on them... They are pricey through the dealer though. I bought my firs one for around a hundy in 04'.. Now my dealer cost is around 189.. I just pulled one at a pick and pull... Less then $15.00.. Kevin
71 gtx.....
[Re: RapidRobert]
#1612140
04/26/14 08:07 PM
04/26/14 08:07 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
You can't compare the engine radiator to a transmission cooler that way. You'll want the transmission pressure line coming in from the lowest linefitting on the cooler to properly/quickly expell any air present in the cooler.
With an engine radiator you indeed do want air to end up in the radiator as that's where the vent/cap is located. On a transmission the vent is in the transmission itself, not in the cooler. So that should be 'airless'.
I reality it's probably not that serious as the line pressure and flow in a transmission cooler is usually high enough to always push out any air either way.
My 2 cents anyway.
[Re: Rob C]
#1612145
04/27/14 08:59 PM
04/27/14 08:59 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
Then to the cooler. Cooler the better for this fluid or any in an engine.
I beg to differ with you on the cooler the fluid the better comment, most ATF has additives in it that are based on general automotive use,based on 160 F operating temps according to Valvoline techs . I bought a new 1998 1/2 Ram 2500 24 valve CTD automatic with the trailer towing package, I installed several after market gauges including a tranny. temp gauge in it, that trucks tranny temps would never exceed 120 F when running empty, the most I ever saw was 230 F when towing my enclosed 24 ft. car trailer at 70+ MPH up the 17 mile long Baker Grade in SO CA Mojave desert in the middle of the day in August, 117 F outside air temps. The fluid would start to go darker as soon as I changed it in the winter or summer, I was told it was due to the fluid temps being to low I did notice the tranny fluid stay brighter if I changed it just before going to a race and back It would get darker after that driving it around town easy When it comes to lubricants warmer (140F+) is better than cooler(below that temps) All the dyno tuning I've done on motors show that they make more HP and torque with hot oil (160F+, the hotter with straight weight oil ) the more power they make
[Re: Cab_Burge]
#1612146
04/27/14 09:39 PM
04/27/14 09:39 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
Pat at SMR Racing transmissions recommended Perma Cool. He said they have no pressure drop. Also no rubber lines, steel or I used PTFE braided lines. http://perma-cool.com/
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
