8-3/4 rear axle yoke question? #1612080
04/25/14 09:21 PM
04/25/14 09:21 PM
Penna
70satelliteguy Offline OP
Penna
I recently swapped my original 742 open 3:23 With 7290 rear yoke for a 489 sure grip 3:23 but now realize that it has a 7260 yoke. My drive shaft will now not fit the smaller rear yoke. I noticed that Mancini has 7260 to 7290 conversion u-joint but not a 7290 to 7260 like I would need to make the drive shaft fit this center section as it is.
My question is if I can easily just swap the rear yoke from the 742 center section to the 489 ? Will the large nut come off with my air gun and tap off with a hammer? Are the splines the same(29?)on a 742 vs. a 489?
Any help would be appreciated!
Thanks Mike
Re: 8-3/4 rear axle yoke question? [Re: 70satelliteguy] #1612081
04/25/14 09:24 PM
04/25/14 09:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I may be stating the obvious, but the 7260 to 7290 conversion u-joint by default is also a 7290 to 7260 conversion u-joint.
Re: 8-3/4 rear axle yoke question? [Re: Alaskan_TA] #1612082
04/25/14 09:48 PM
04/25/14 09:48 PM
What Alaskan TA said. You could very likely get one locally & be up & running quicker. Ask for a "Mopar 7260 to 7290 conversion ujoint" and there are different brands and spicer and neapco are high quality. Not sure of the quality of the Mancini brand or what your horsepower/app (stick/racing/street) is. the neapco # is 2-0527. On a high horsepower app you'd want a non geaseable "solid" ujoint (no zerk) & you grease the caps by hand upon installation & open it up & regrease the needles at regular intervals & not sure if that is available in the 7260/7290 type we are after here. it's stronger cuz there is no hollow passage inside for the grease to flow to the 4 corners. But to k.i.s.s. I'm thinking a regular conversion joint of any brand (Mancini or otherwise) will do you fine but I'd be surprised if one of your parts houses did not have em on the shelf
Re: 8-3/4 rear axle yoke question? [Re: RapidRobert] #1612083
04/25/14 10:30 PM
04/25/14 10:30 PM
Penna
Penna
Thanks, was not sure if the conversion worked both ways or not!
Mike
Re: 8-3/4 rear axle yoke question? [Re: 70satelliteguy] #1612084
04/25/14 10:53 PM
04/25/14 10:53 PM
BDW Offline
BDW  Offline
Re: 8-3/4 rear axle yoke question? [Re: 70satelliteguy] #1612085
04/26/14 09:26 AM
04/26/14 09:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Unless you have a crush sleeve eliminator in the 489 you dont want to pull the yoke.Once pulled if it has a crush sleeve eliminator you have to get it back to spec after its removed.Rocky
Chrysler Firepower
Re: 8-3/4 rear axle yoke question? [Re: BDW] #1612086
04/26/14 09:29 AM
04/26/14 09:29 AM
Penna
Penna
Thanks CNXC
Re: 8-3/4 rear axle yoke question? [Re: 70satelliteguy] #1612087
04/26/14 01:34 PM
04/26/14 01:34 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I just wanted to add the I think the correct NAPA # is a 347.
It's Swifty! Swifty, you toad sucker!
Re: 8-3/4 rear axle yoke question? [Re: zrxkawboy] #1612088
04/26/14 02:41 PM
04/26/14 02:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The old NAPA number was 347, but it has been superseded so 347 no longer comes up in their system.
Re: 8-3/4 rear axle yoke question? [Re: Alaskan_TA] #1612089
04/26/14 03:44 PM
04/26/14 03:44 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Go to napaonline.com and type 347 into the search box - it's there.
Re: 8-3/4 rear axle yoke question? [Re: zrxkawboy] #1612090
04/26/14 04:03 PM
04/26/14 04:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Interesting. The last time I asked for one here in town they told me the number was no longer valid. They still had it, just a different part number.
Re: 8-3/4 rear axle yoke question? [Re: Alaskan_TA] #1612091
04/26/14 05:10 PM
04/26/14 05:10 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Yeah, I think they changed their numbering system for awhile, and then changed back. Not really sure of the whole story. I work part-time at the local NAPA, but only work about one Saturday a month anymore, so I struggle to keep up with the changes!
Re: 8-3/4 rear axle yoke question? [Re: zrxkawboy] #1612092
04/27/14 12:26 AM
04/27/14 12:26 AM
scratchnfotraction Offline
my local napa does have to cross it back to their old 347# but they have it next day most times.
you have to get a counter clerk not a counter jerk to look it up.
