Questions on '78 440 out of a Winebago #1611771
04/25/14 01:17 AM
04/25/14 01:17 AM
Texas
TX65Coronet Offline OP
Texas
I'm trying to finish my car before I graduate HS the first week of June and I need some help. I'm putting a '78 440 out of a Winebago into my '65 Coronet. Having problems finding the correct alternator & alt bracket for this. Have heard "yes this is the part you need" waaaay too many times.....and of course it isn't what we need. No A/C and no power steering. All I need is the correct pulleys for crank, H2O pump, & alternator.....along with bracket. Thanks.
Re: Questions on '78 440 out of a Winebago [Re: TX65Coronet] #1611772
04/25/14 01:46 AM
04/25/14 01:46 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Bouchillon has brackets. Mancini Racing too.
Re: Questions on '78 440 out of a Winebago [Re: TX65Coronet] #1611773
04/25/14 10:14 AM
04/25/14 10:14 AM
scratchnfotraction Offline
my stock non a/c brackets/pullys worked with a newer mini alt on my 78 MH 440 engine.
Re: Questions on '78 440 out of a Winebago [Re: Kern Dog] #1611774
04/25/14 10:49 AM
04/25/14 10:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Bouchillon is who helped me and it was right the first time.
Re: Questions on '78 440 out of a Winebago [Re: scratchnfotraction] #1611775
04/25/14 12:22 PM
04/25/14 12:22 PM
Georgia
Steve Bryant Offline
Georgia
There are only two brackets. One looks like a triangle and the other is a longer piece with a slot. I got mine from 440 Source for $30 and they worked great. As for the alternator goes it has more to do with the car you are using and how the charging system is setup/targeted; Squareback, round, number of fields, wiring harnesses, voltage regulator etc.
You will need to buy a single belt which will run between the water pump, alternator and crank. You can get that from your local part store. Just ask for a 440 Alternator belt for a Dodge B300 or 70 Cuda with a 440 without AC.
Lastly, you will need a bolt and spacer kit for the alternator and brackets. 440 Source has these as well for $17. I have heard people complain about 440Source as some of their parts are from China but for things like this, I think they are great.
Re: Questions on '78 440 out of a Winebago [Re: TX65Coronet] #1611776
04/29/14 12:57 AM
04/29/14 12:57 AM
Texas
Texas
Thanks for the quick responses. I'm a little slow getting back. Looking forward to gaining some knowledge and getting my car on the road.
Re: Questions on '78 440 out of a Winebago [Re: Steve Bryant] #1611777
04/29/14 12:51 PM
04/29/14 12:51 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
My alternator bracket and water pump pulley are originals, but I bought a crank pulley and the spacer kit from 440Source and I thought it was great. Much cheaper than "Resto" stuff from other sources, and the quality was nice. I'd buy the other stuff from them in a heartbeat. Pick up one of each of the crank pulley spacers too just in case.
As said the alternator will be a "for your car" application. Avoid the temptation to go with some ultra high amp replacement alternator. Use a 35-45ish amp unit, your car probably came with something in the mid to high 30s. You need a single field setup. If you still have a points style voltage regulator convert to the replacement electronic.
