Scratchin: I planned on having everything after the y pipe be new 2.5 single pipe, then the 1in/2out muffler for dual tips. Even with me doing the cat delete at home, if they are wanting anywhere near $200 to do their part of the exhaust, Im just going to spring for the bolt in true dual kit and do it myself. And judging by their past prices they will be charging at least that.
76dodgeboy: I saw that you responed to someone else, just wanted to let you know that I had not actually verified that they have it in stock.
340: Since the 4x4 pipe will work, if I end up doing the single and eliminating the the cat myself, I'll just use it if its available.
I'll know which route Im going to go when the exhaust shop gives me their quote. Im almost hoping for a high number so I'll have an excuse to spring for the bolt in true duals kit.
roe
