Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: 383man] #1610707
04/23/14 11:02 PM
04/23/14 11:02 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
10.3 for 71 down from 10.5, but not sure how that was reached maybe the j heads have a couple more cc's? My early 71 intake has no jets in the floor, also remember reading the auto trans having a higher shift point due to a governor change??
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: 383man] #1610708
04/23/14 11:14 PM
04/23/14 11:14 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think some books state the 71's at 10.0 and the 70's at 10.5 comp ? I also dont remember if it was 71 or 72 when they started putting EGR jets in the bottom of the intake manifold ? Ron
I beleive the 1973 Thermoquad intakes where the first SB 4 barrel intakes to have the EGR jets in them The NHRA blueprint speces for the 1968 to 1971 340 4 barrel motors are the same on all the specs. I use to help and consult with one of the more successful NHRA Mopar SB racers in SO CA., he could swap the intake and carbs. on his Challenger and add weight so he could run 6 different NHRA stock clases,(C/SA through G/SA) with the same long block and still be legal
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610709
04/23/14 11:14 PM
04/23/14 11:14 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Properly dialed-in, my money's on the '71...
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: RSNOMO] #1610710
04/24/14 12:16 AM
04/24/14 12:16 AM
Phila Pa
scatpacktom Offline OP
Phila Pa
X heads may be a tad better than a J head
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610711
04/24/14 02:06 AM
04/24/14 02:06 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Maybe but I think most 71's had the j's
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610712
04/24/14 02:36 AM
04/24/14 02:36 AM
Not on the dyno testing I've done, with the same flow numbers on both The X have the valve eyebrow protrusion issues that need to be resolve on a blueprinted all out stocker motor, the J heads don't Or maybe I have it backwards It's been close to 20 yrs since I've touched a competetive SB MOpar stocker motor
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: Cab_Burge] #1610713
04/24/14 09:54 AM
04/24/14 09:54 AM
Phila Pa
Phila Pa
X head flows a little better than the later J head, just by a smidge. The X was designed as a 2.02 head, the J a 1.88. They put 2.02 valves in the J's for 71 but you know what that does to the short turn. If you had the choice of the two you would choose the X head for 1970
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610714
04/26/14 10:36 PM
04/26/14 10:36 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
wouldn't it have been nice in 1971 if Ma used the 69 4-seed cam with the X heads and the 70 exhaust manifolds with the 71 t-quad and intake.. or 6 pack
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610715
04/26/14 10:49 PM
04/26/14 10:49 PM
Minnesota, USA
Sublime70 Offline
Sublime70  Offline
Minnesota, USA
By the way, J heads were phased in during 1970 model year,and not just on AAR's and T/A's. They had 2.02 intakes etc. Some argue that the J's flow marginally better, but from what I have seen it is a wash.
The earliest 340 4bbl J heads that I have seen are dated October 1969. I am always looking for older dates, I have been trying to figure out when they started using them in 1970. If anyone has pictures of earlier non -T/A J heads please send me a picture. Thanks.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: Sublime70] #1610716
04/29/14 11:38 PM
04/29/14 11:38 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
What about the 1968 340 four speed? From what I remember they had a bit different cam and thus better performance.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: sawdust] #1610717
04/30/14 10:16 AM
04/30/14 10:16 AM
Phila Pa
Phila Pa
68 4sp had a lumpier camshaft. Maybe a 4sp 68 notch would be the hot ticket.
