Re: cyl. heads size and ci. [Re: Bigcube] #1610524
05/15/14 12:16 PM
05/15/14 12:16 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
Thanks BigCube, that is pretty close to what I was thinking on camshaft.
Lee, it broke the head off off #7 exhaust valve, cracked the cylinder and piston. It tagged all the exhaust valves but truthfully didn't hurt the head that bad, I think a new exhaust seat and some new valves and the heads will be ok. I got lucky it sat the head of the valve in the seat. The heads are on their way to Huntsville Engines, Andy says 2-3 weeks on those. The aluminum block and crankshaft should be ready for me to pick up in 2-3 weeks also. I'm hoping what I won Saturday will pay the machine shop bills!
I think the 511 is repairable but won't know for sure till I get it completely tore down. The timing cover is pushed out to the back of the water pump in a perfect circle, I think as strange as it sounds that the lifters jumped lobes and that is why it touched all the exhaust valves.
I was using a chrome stock type timing cover with no support in front of it. Normally I run an aluminum cover or a piece of aluminum angle bolted to the cover bolts.
Re: cyl. heads size and ci. [Re: jafr] #1610525
05/15/14 02:09 PM
05/15/14 02:09 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Is that a chebby head cause I NEVER see any Mopar stuff at Huntsville engines? For that matter I NEVER see them doing much besides working on tube racks. I dropped a set of SB heads there once while Gerry Reavis was still alive for them to check the valve spring pressures and flow - 3 weeks later they hadn't done it.
GL with the rebuild.
Re: cyl. heads size and ci. [Re: Airwoofer] #1610526
05/16/14 11:57 AM
05/16/14 11:57 AM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
LOL, no they are 440-1s. They repaired a set of SR heads for me last year and completely rebuilt a chamber.
Re: cyl. heads size and ci. [Re: jafr] #1610527
05/16/14 11:59 AM
05/16/14 11:59 AM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
After picture!
