i have the worst luck repainting things...
#1610151
04/21/14 01:13 AM
04/21/14 01:13 AM
Posts: 4,179 California
mickm
California
i went to repaint the oil pan, which i had done with self-etching primer and mopar rattle can paint. i used some paint stripper, and it took the paint off nicely, but didn't take the primer all the way off, and left a not smooth surface. so i hit it with another round of stripper, and blasted it with the hose, hooked up to hot water.
it looked good, and seemed to take a lot of the primer off, but not all the way to metal. so i wire brushed it, got it nice and smooth, went over it all with scotchbrite, and then washed it with tide and a scothbrite type sponge. came out really nice. lots of traces of the primer, but smooth to the touch yet roughed up slightly from the wire brush.
painted it again, and it looks like crap. raised areas all over the place, i'm assuming corresponding to where the remains of the primer was.
so what now? i figured it was ok to leave that last bit of primer on there, but apparently not.
i don't want to media blast it, as that could leave little particles tucked in the baffles inside, but i assume i have to get this all the way to bare metal.
how do i clean this thing up and get it ready to paint again?
Re: i have the worst luck repainting things...
[Re: mickm]
#1610153
04/21/14 12:28 PM
04/21/14 12:28 PM
Challenger 1
Cincinnati, Ohio
Don't use primer only engine paint. That's the problem. Wet sand it with water, start with courser paper and finish with 320 grit.
You don't need primer, it's not hi temp rated. I have painted at least 30 motors and never used primer, the motor get's too hot for primer.
[Re: Challenger 1]
#1610154
04/21/14 02:07 PM
04/21/14 02:07 PM
mickm
California
it looks that way. it's amazing how well the primer stuck to the metal, and how poorly the paint stuck to the primer.
time to strip it again and get it to bare metal...
[Re: His and Her 69's]
#1610157
04/22/14 03:52 AM
04/22/14 03:52 AM
mickm
California
We have blasted the pans before and what you do is seal off the inside of the pan. I use cardboard and the wide green painters tape and I make sure it is sealed off so no sand gets in. rinse it before you take off the tape etc. After the outside is clean then do the inside with brake clean or something, then a Good blow dry. Paint or primer away. David
i was thinking of that, sealing it off really well.
i'll give that a shot. easier than trying to get all that damn primer off by hand!
thanks!
[Re: RSNOMO]
#1610159
04/23/14 02:28 AM
04/23/14 02:28 AM
mickm
California
Get it stripped, and properly prepped...
Is primer needed???
While not OEM, I'm of the belief that primer exists for a reason...
Would you put color over bare sheet metal???
I prepped, primed, and put color on an engine that's gone 20+ years..
It's holding up real well...
ok, so here's another question: what does properly prepped mean?
[Re: Stanton]
#1610161
04/23/14 01:01 PM
04/23/14 01:01 PM
mickm
California
stripped, wiped with oil & wax remover, wipe with tack cloth, prime, paint
what primer do you use? when i painted the engine i used self-etching primer. the primer stuck like glue to the metal, the paint didn't stick well to the primer at all.
[Re: Kern Dog]
#1610165
04/26/14 02:05 PM
04/26/14 02:05 PM
Posts: 4,669 Wichita
GY3
Wichita
I use a wire wheel on a 4" DeWalt grinder, then always spray SEM Self Etching primer on all tin. Cast iron? Nah....But always use primer on the tin.
Yep, braided wire cup wheel will make short work of it on an angle grinder.
[Re: Kern Dog]
#1610166
04/27/14 02:14 PM
04/27/14 02:14 PM
mickm
California
that's what i used as well. primer stuck to the metal like glue, paint stuck to the primer like, well, not glue. chipped and knocked off very easily.
of course it is mopar paint. i've had good luck with it in the past, but i know many people don't like it. i think this time i'm just going to rough the surface with 320 grit, and go with straight paint. can't be any worse than it was...
well, i hope not!
[Re: BarrsRestoration]
#1610168
04/28/14 03:39 PM
04/28/14 03:39 PM
mickm
California
Even though some of the primer remained, it was still affected by the chemical stripper. Any time that you use a chemical stripper, you have to remove every single layer and every trace of paint, primer and filler. ANYTHING touched by stripper that remains will cause adhesion problems when you re-coat it. We scrape, then scrub with soapy water and a scotch-brite pad. Rinse, completely dry, then blast or sand any remaining material off.
yes, i learned that. stripped it completely, washed it with a degreaser, then hot soapy water. rinse, sand with 320 grit, and painted and nice and shiny!
