Re: 9.25 vs 8.75
[Re: redraptor]
#1609806
04/20/14 10:14 AM
04/20/14 10:14 AM
Posts: 1,519 AZ
Mike P
AZ
I've run several of both in various projects (currenly have a 9 1/4 in the 57 Plymouth with a 1st Gen Hemi and 4 speed).
I personally like the drop out center section of the 8 3/4 but I can find the 9 1/4s for about 1/2 the price of the 8 3/4s.
As far as strength and reliability my experience is that is about a wash.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 9.25 vs 8.75
[Re: Mike P]
#1609808
04/20/14 10:32 AM
04/20/14 10:32 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
The guy wanting a center section has a twin turbo setup currently running 13s but he said he's upgrading turbos to run 10s.
Actually, shame on this guy. IF he can afford a car like that and run those numbers, he SHOULD have already known the answer and the discussion closed.
Re: 9.25 vs 8.75
[Re: Commando1]
#1609809
04/20/14 01:26 PM
04/20/14 01:26 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Lots of 4,000 lb Dakotas with stock 9.25s in them running 11s. And even a handful into the 10s Seems strong enough to me.
**Photobucket sucks**
Re: 9.25 vs 8.75
[Re: Commando1]
#1609810
04/20/14 01:51 PM
04/20/14 01:51 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
He's wanting 8.75 stuff Not 9.25. the kid is the one saying through 9.25 is better. I mentioned converting a truck D60 over to 5lug and told him to contact DoctorDiff
Re: 9.25 vs 8.75
[Re: 76dodgeboy]
#1609812
04/27/14 01:59 PM
04/27/14 01:59 PM
Posts: 4,968 WI
Dcuda69
WI
Ummm....am I the only one here that thinks he has more issues than just the rear end???
Re: 9.25 vs 8.75
[Re: Dcuda69]
#1609813
04/27/14 02:23 PM
04/27/14 02:23 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Maybe it's a twin turbo slant 6 in a C body?
Re: 9.25 vs 8.75
[Re: 70Cuda383]
#1609815
04/27/14 05:17 PM
04/27/14 05:17 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The issue with C clip rearends was made famous by GENERIC Motors. The Mopar 8 1/4" and 9 1/4" axles do not have the same type of failures.
Re: 9.25 vs 8.75
[Re: Kern Dog]
#1609817
04/27/14 05:35 PM
04/27/14 05:35 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The only downside to the 9-1/4 is the cost of aftermarket parts - but then if you drive a Mopar you're already used to that! FWIW, the 9-1/4 is a true "Mopar" item - unlike the dana. The strength comes from the ring gear size so the 9-1/4 should be stronger than anything but a dana - given the same quality of gear in each. It is apparently easier to work on than a dana.
If you were going to buy a rear end and then shorten it, swap gears and diff, etc, etc, then there's no excuse not to go with a 9-1/4 versus an 8-3/4.
Re: 9.25 vs 8.75
[Re: BulletBob]
#1609820
04/27/14 10:23 PM
04/27/14 10:23 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
mine failed when I broke it mud riding an 80' model I had once
That tire/wheel,axle stub & brake drum came out of there just a fast as my old 66 GTO axle did when introduced to slicks & 550 ft lbs of torque & a 4800 rpm clutch dump
I don't see the difference
You could take an axle out of a Kenworth big rig and stuff it under your car and in the right circumstances break it! That doesn't mean its a weak rear end !!!
My feeling is that a 9-1/4 would not break under the same circumstances as that POS GM unit. However, the GM unit would not have lasted as long as the 9-1/4 in the mud.
If you're going to compare things, do it on equal terms !!!
