Re: Ok is this going to be a problem child ? [Re: dogdays] #1609573
04/20/14 12:29 AM
04/20/14 12:29 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How about because it's easier to make power with compression, and E85 supports some pretty high compression ratios.
To go 10.90`s? Ya, that makes sense..............
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609574
04/20/14 12:41 AM
04/20/14 12:41 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I did't mean for this to happen. I got a good deal on this short block. so I bought it. He told me it had 12.5 to 1 with his 75cc heads. LOL wrong ! and it had small domes on it. so now I am try to do the best I can with what I got.
Your thinking is correct, that if you optimize this combination you will likely be over the limit of a stock block unless you go easy. But going easy is tough to do when you want to see what it can do.
Why not take the domes off and rebalance?
Re: Ok is this going to be a problem child ? [Re: viperblue72] #1609575
04/20/14 06:33 AM
04/20/14 06:33 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Why not put a bigger cam in it, back the timing out a little and rev it to maybe 63-400. That way you're within your comfort zone but will still probably run mid 10's. I shift my .590 at around 6300 with nearly 13.1 comp, trap at 6700 and it's pulling like a train.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609576
04/20/14 08:28 AM
04/20/14 08:28 AM
ill
dennismopar73 Offline
ill
It will he fine, stock blocks have no issues till.you get over a magical 512 number in full race mode,
I run stock rods shift 6500 cross the line at 6800.
A 494 (500)) ci will have no issues , in fact should be a great build
Far as camshaft goes you have to ask is it race or street ,or combo.
Really not much difference, .
I'm not a large centerline guy never want to see a 110 or above stuff
That kills low end , a 494 will be have a ton of tq so why build something that requires rpm ?
Re: Ok is this going to be a problem child ? [Re: dennismopar73] #1609577
04/20/14 11:10 AM
04/20/14 11:10 AM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Cab I been running e-85 for years now. so same carb. This a Bracket race only. going to put a UD640 lift cam in it. at 102 and baby it LOL
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609578
04/20/14 01:28 PM
04/20/14 01:28 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The CR is not to high,and its perfect to run E85 and even better to run alcohol.I think you would like the alcohol better than the E85 and it would make a lot more torque,more torque=more power/speed with out having to raise the RPM level.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
