Would a 96 Ram Van 318 have a magnum roller motor ? #1609315
04/19/14 11:26 AM
04/19/14 11:26 AM
Looking at a 96 Ram Cargo Van 2500 with a 318, 77k miles.......any thoughts good/bad ? Is the 2500 just a 1/2 ton with more leafs ? Any known/common issues ? Thanks
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609316
04/19/14 12:02 PM
04/19/14 12:02 PM
scratchnfotraction Offline
yes, 5.2 magnum engine
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609317
04/19/14 02:46 PM
04/19/14 02:46 PM
Guitar Jones Online laugh2
It probably still has 5 lug wheels, depends on the load rating. I never cared for the front ends on them, the steering boxes are typically sloppy and the steering linkage is prone to wear as are the suspension bushings.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: Guitar Jones] #1609318
04/19/14 04:31 PM
04/19/14 04:31 PM
Yes, it does have 5 lug 15" wheels....for a work van it just seems wrong.....I may have to go with the ferd e-250/e-350....
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609319
04/22/14 08:10 PM
04/22/14 08:10 PM
Well, I bought this 1996 Dodge 2500 Van today, it was just too good of a deal and very very well maintained...and I liked the fact that it has a 3 speed automatic instead of the overdrive....much cheaper if anything ever goes wrong
It has 76,000 miles and runs and drives fantastic. The only 2 things that bother me.....is it doesn't just pop off, sometimes have to crank a bit......and the rear end is howling, probably sounds worse because it's an empty cargo van....the original owner took very good care of it and he just changed the rear end lube.....would this rear take any kind of special additive ? It does have 3.90 gears, not sure if it is a suregrip
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609320
04/23/14 03:06 AM
04/23/14 03:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
if it growls from the moment it starts rolling, getting louder with speed, it may be the pinion bearings, especially in a 9 1/4 rear. The long cranking is not normal. All my injected dodges (even the tbi ones) fire NOW when cranked.
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609321
04/23/14 11:55 AM
04/23/14 11:55 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
No limited slip additive usually will just cause a moaning type of sound around turns.
The 9 1/4 rear ends are known for early pinion bearing failure and have a flimsy axle bearing design as well.
I just had to rebuild the one in my 1500ram p.u. also with only 75K miles on it .
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609322
04/23/14 12:38 PM
04/23/14 12:38 PM
ccarson Offline
ccarson  Offline
Its a magnum engine great engine, a cargo van is not a quiet ride
new, used, empty, full.
If your worried about it rebuild the rear change all the bearings,if not change the gear lube with synthetic and add the shear grip additive
change all the rest of the fluids and abuse it.
I've had three of them, wish I still the last one a 2000, 1500 with a 5.9 Magnum, I pulled my 24' United Enclosed with it! not fast but it would pull it loaded no problem, great van's
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ccarson] #1609323
04/23/14 09:11 PM
04/23/14 09:11 PM
It is noisy right away, and seems to quiet down after 5-10 miles.
How would I tell if this is a 9.25 Rear end ? Turns out his paperwork shows it has 3.21 gears. And would it be relatively easy to replace the pinion and carrier bearings ? Meaning probably just replace the bearings and not the races ? Install the same shims ?
Would the cranking issue probably be related to a weak fuel pump ?
It has a 3-speed automatic....727 trans correct ?
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609324
04/24/14 05:38 PM
04/24/14 05:38 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
That sounds more like the tires to me.
I would run it in gear with the wheels off the ground to pin point where the noise is coming from . if it,s quiet up in the air , it,s probably just the tires.
Changing the bearings without new races is a waste of time and money. With all the right tools it,s fairly easy ,without them it,s a p.i.a. the 9.25 has a 12 bolt cover shaped like a stop sign.
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ChinooK440] #1609325
04/24/14 07:44 PM
04/24/14 07:44 PM
It has new Michelins with just over 2,000 miles on them.....but I will isolate the noise before ripping anything apart.
I see Rock Auto has a rebuild kit that includes inner and outer pinion bearings, Carrier bearings, shims and gasket.....I suppose I might as well do the wheel bearings also.
Any special tools or tips if I do tear it apart ? I know I need a socket for the pinion nut....probably a slide hammer puller to get the races out....and a driver to install the races....then need the bearing pressed off and on the axles ??
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609326
04/25/14 12:07 AM
04/25/14 12:07 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
My 89 (an early roller, not magnum, TBI) likes one cycle of the key to on, then off then start to kick off quickly. If you just crank, it's slower to start. I figure it's priming better with 2 quick pump runs.
96 is a whole different creature, but try it.
Re: Would a 96 Ram Van 318 have a magnum roller motor ? [Re: ] #1609327
04/25/14 09:21 AM
04/25/14 09:21 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
The axle bearings are pressed into the housing on these style axles,you use a slide hammer type axle bearing puller to remove them and a simple driver /socket& hammer to install them.
You also nee quite a few other tools, many of which you can make if you have a welder etc. :
carrier bearing adjuster
yoke holder
bearing seperator/splitter
hydraulic press
small inch /lb torque
3/4 drive breaker bar n socket for pinion nut
Do some research on google , youtube and a factory manual before hand to get familiar with it first.
