Re: tunnel ram vs. single plane
[Re: AndyF]
#1608982
04/20/14 10:54 PM
04/20/14 10:54 PM
Posts: 1,303 Penna
70satelliteguy
Penna
"I think that is a good tunnel ram so you will probably be hard pressed to beat the power with a single plane intake. But I've run more than few dyno tests where the tunnel ram is a dog. Some of the old school tunnel rams are very weak when compared to a good single plane intake." I am Currently running the Indy 3X with a Quick fuel 1250 on my 572.It runs pretty good! If I did not have so much invested already I might be tempted to try a tunnel ram but I would want to pick up a lot more than a tenth or so or "The juice would not be worth the squeeze" for me! I do think they look awesome though! Mike
[Re: 79410aspenrt]
#1608984
04/21/14 09:01 AM
04/21/14 09:01 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
do you guys think it would be worth putting 750's on instead of the 650's?
Yes I do.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Harley]
#1608989
04/21/14 07:00 PM
04/21/14 07:00 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I went 2 tenths faster with the tunnel ram over my single 850.
Car looks good harley
[Re: joedust451]
#1608990
04/21/14 09:30 PM
04/21/14 09:30 PM
Posts: 253 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
I've had the tunnel ram on for 6 years, haven't tried a single plane or for that matter thought about it.
What kind of 750's should I look at? Holley, quick fuel, pro systems..........
[Re: 79410aspenrt]
#1608991
04/22/14 01:46 AM
04/22/14 01:46 AM
joedust451
super gas
super gas
Branson, Mo.
AED is getting a very reputation lately, might want to give them a call.
[Re: joedust451]
#1608992
04/22/14 01:40 PM
04/22/14 01:40 PM
Posts: 996 Queens, New York
Harley
Queens, New York
Thanks Joe.
[Re: 79410aspenrt]
#1608996
04/22/14 09:44 PM
04/22/14 09:44 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
My custom built Quickfuel 750's had the wedge shaped tunnel ram floats, the carbs were pretty much dead-on right out of the box, never had to mess with idle or anything once it was set, best carbs I've ever owned.
[Re: ProSport]
#1608997
04/22/14 10:38 PM
04/22/14 10:38 PM
79410aspenrt
Saskatchewan (SK)
I run -8 braided line from tank to pump. from pump to regulator also -8 braided line. from regulator I run -6 to carbs.
Prosport, did you buy your quickfuel carbs from them or summit, jegs....?
what did they cost?
