Re: crower roller lifters
[Re: blindboyscuda]
#1608295
04/16/14 09:42 PM
04/16/14 09:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
hello friends time to choose roller lifters for a 650 lift fun street cam. will the 66284 work with a stock 440 block. i am told by one person they will but then another says they won't. the person that says they will not work says it is because stock blocks with solid flat tappet had smaller holes for oiling and the hydraulic flat tappet blocks had bigger holes for oiling. is this true? how would i find out and can i use the 66284in a stock 440 block? I have a friend that is willing to sell these so it is either a yes or bust.
When the block is cast they have NO CLUE where the block will go let along what cam is going in it... so thats BS... maybe some years had a slightly smaller hole in the lifter bores but I even doubt that.. but it could have been a error if there was a bit smaller
[Re: blindboyscuda]
#1608297
04/17/14 11:28 AM
04/17/14 11:28 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Simply not true like Mike mentions. Now their production tolerances, thats another story in itself....
RIP Monte Smith
[Re: CompWedgeEngines]
#1608298
04/17/14 11:37 AM
04/17/14 11:37 AM
MR_P_BODY
I wish those hole were a lot smaller.. it would help with some of the larger lift cams so they wouldnt uncover the lifter ring area... but most times its the champfer on the top of the lifter bores that is the problem along with that hole
[Re: blindboyscuda]
#1608303
04/17/14 02:52 PM
04/17/14 02:52 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I've used the Crower race solid roller lifters with the .820 or .850(CRS disease ) diameter wheels with good results on the street I don't remember the part number now but they where the ones with the solid bodys, no cut outs on the main bodys or pressure oiling to the axles. Most of the iron aftermarket blocks have the raised, taller, lifter bores so you need a taller body or a taller top for the link bars to clear the blocks Lots of choices out there, I have used a bunch of different ones over the years, buy good ones once, not cheaper bad ones more than once
