Re: Difference between alternators??
[Re: WyleECoyote]
#1606333
04/12/14 03:18 PM
04/12/14 03:18 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Square backs usually had higher amperage output.
The change in the case was due to a new design of the components. Unless you have a rather unusual mounting arrangement the two alternators will interchange.
[Re: WyleECoyote]
#1606335
04/12/14 04:56 PM
04/12/14 04:56 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
You need an extra wire for the square back field also[it has 2 fields].That and if you have a point reg toss it and get the replacement that looks just like it but is solid state.
Chrysler Firepower
[Re: WyleECoyote]
#1606337
04/12/14 06:22 PM
04/12/14 06:22 PM
RapidRobert
I would think your 71 would already have the "B" 2 field terminal alt system with blue and green field wires. Otherwise as said space it forwards or backwards till the pulleys line up & swing it out with a longer bracket/belt as needed & if you only have the 1 green field wire on your 71 then just ground either one of the alt field terminals to the nearby alt case & instead you can unground the brush/brush holder so it's now grounded to it's case mounting nub for a cleaner appearance & if you are purchasing one I'd ask for one for an 85 M body iirc, which is a 78 amper
[Re: RapidRobert]
#1606338
04/12/14 08:33 PM
04/12/14 08:33 PM
therocks
Niles , Ohio
Square back on my 65 BB and the bracket fits like it did with the OE alt.I run an old MP water pump with the odd bracket so Im not sure if that changes anything.Rocky
Chrysler Firepower
