C Body front subframe
#1605855
04/11/14 04:34 PM
04/11/14 04:34 PM
Posts: 416 Georgia
KingTuna
Georgia
I was doing some research, and I saw where someone said you can interchange the front subframes on the 66-73 C bodies. I have a 73 new yorker donor car for parts, and was wondering what all it would take to swap the front subframes. My thinking behind this is that the new yorker should have larger torsion bars up front, and should help with handling in the Fury once I drop the 440 in. Also, I am planning on using the disc brakes from the New Yorker, so swapping sub frames would accomplish that. What are your thoughts on this, and would the extra work be worth the outcome?
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
Re: C Body front subframe
[Re: KingTuna]
#1605856
04/11/14 05:29 PM
04/11/14 05:29 PM
Posts: 416 Georgia
KingTuna
Georgia
Ok, so just found out that the subframes will not interchange. Stupid me.
[Re: KingTuna]
#1605857
04/11/14 06:27 PM
04/11/14 06:27 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
i have a '68 NY with power disc front brakes complete. parting out car.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: feets]
#1605861
04/13/14 09:43 AM
04/13/14 09:43 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Why do you say that?
Some will interchange while others won't. I don't recall the matching arrangements.
All 65-73 are interchangable even though there are differences between them.
Plymouth stub frames were 2" shorter from 1965 to 1968(?) than Dodge and Chrysler. But they all interchange. 1968-1973 Imp stub frames are a different design but still interchange.
The key is that all the body mounting locations are the same regardless of make, model, and year.
I once heard 74-78 stub frames will also interchange but I never seen it done so I won't say that they can also.
Nowhere did I say they were all identical.
[Re: 440newport]
#1605864
04/13/14 02:21 PM
04/13/14 02:21 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Plus Imps used a different bolt pattern on the wheels.I had to get a GM rotor at the JY for one of mine.You dont want discs that are the old 4 pistons.Lots of $$$$ to repair if you can find parts.Rocky
Chrysler Firepower
