1969 plymouth A/C
#1605779
04/11/14 08:31 AM
04/11/14 08:31 AM
Posts: 1,174 Woodbridge
Tommy The Chryco
Woodbridge
does anyone have a supplier for a A/C heater core? thanks
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 1969 plymouth A/C
[Re: Commando1]
#1605783
04/12/14 09:41 AM
04/12/14 09:41 AM
Posts: 6,379 Abilene, Texas
fastmark
Abilene, Texas
I bought one for my 70 because OEM ones are impossible to find.
What are you talking about. They are all over the place. Including ebay...
http://www.ebay.com/itm/65-68-CHRYSLER-3...cfb&vxp=mtr
My point exactly. That is not an OEM heater core. That is the one that Classic auto Air repops. It is way more expensive than the original brass heater core.
[Re: fastmark]
#1605784
04/12/14 08:27 PM
04/12/14 08:27 PM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
A few deades ago, if I needed a new heater core, a radiator shop would fabricate one exactly like the OEM using my original nozzles.
Might be able to do that nowadays if you can find a capable radiator shop run by an old timer.
Caveat: BE SURE to pressure test before you go to the trouble to re-install it! I had a few apparently pass the pressure test at the shop, then fail another test a few days later.
[Re: fastmark]
#1605785
04/13/14 09:52 AM
04/13/14 09:52 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
And my point is that it will be a lot cheaper than an original brass OEM heater core because you'll never find one.
Plus.... The OEM brass ones leaked given long enough. Like the aluminunum OEM REPLACMENT ones given long enough.
You won't own that car long enough.
