Does anyone make single-stage touch-up paint? #1604431
04/07/14 05:34 PM
04/07/14 05:34 PM
Somewhere near Palm Springs
ConvertiBee Offline OP
I'm hoping to find a company that offers T7 Bronze in a single-stage enamel spray can. I know Totally Auto offers original paint colors, but (and here's the stupid part!) It's only available as a 2-stage base/clear system. The reason that is stupid is because (A) It's not going to be usable with any original paint car and (B) If you DID have a 2stage paint job on your car, then chances are very high that you could just go back to the original supplier of that paint to get your 2-stage fix.
So: Who sells original color single stage enamel in rattle-cans?
[img]https://photos.google.com/search/_tra_/photo/AF1QipP622C0UgUgrRn9SDVmwoPXVW4gJ4A2UcAzWOit[/img]
'69 GTX 440 D21 A34 N96
'70 Coronet 383 'Vert
'71 Demon 340 SixPack 4-Speed
'72 Cuda 340 FE5
'74 Kawasaki Z1, and...
(12) Japanese Enduro's and SuperBikes from the 1970's! smile
Re: Does anyone make single-stage touch-up paint? [Re: ConvertiBee] #1604432
04/07/14 05:36 PM
04/07/14 05:36 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
When I bought the single stage for my son's 73 Plymouth, the local auto paint supplier said they can either tint some single stage in a spray can or could even mix the gallon and pull some out to put in a rattle can.
So if you havent bought your paint already that may be an option.
Re: Does anyone make single-stage touch-up paint? [Re: bohmer2] #1604433
04/07/14 06:35 PM
04/07/14 06:35 PM
Thanks Bohmer, but I have an original paint car (1969 GTX) and I recently had the trunk floor replaced... just the center section. The "wings" are intact, and I would like to spray the center, overspraying & feathering out onto the wings (side pieces) a bit.
'72 Cuda 340 FE5
Re: Does anyone make single-stage touch-up paint? [Re: bohmer2] #1604434
04/07/14 06:37 PM
04/07/14 06:37 PM
MA
steve70 Offline
steve70  Offline
MA
Any auto body supply shop can mix you single stage in a spray can, usually for less than $20
1970 Challenger T/A 4 speed
Re: Does anyone make single-stage touch-up paint? [Re: ConvertiBee] #1604435
04/07/14 08:02 PM
04/07/14 08:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've NEVER seen an area that large done with a spray bomb that didn't look like it was done with a spray bomb - regardless of the make of the product. And overspraying to "blend" just won't work - you'll end up with what looks like exactly that - overspray!
If it were me I'd get a pint of single stage and shoot it with a touch up gun - even a cheap one will do - refilling the cup a few times if need be. Doing it this way it will have a slower drying time and you can maintain a "wet edge" on the large surface. Also, I would mask the area with a "soft edge" at the seams. When you're done the repair it would be virtually undetectable except for it being new paint.
