Re: Organisol "look" and "texture" [Re: Grizzly] #1604145
04/26/14 12:08 PM
04/26/14 12:08 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Does that paint have UV protection?
Re: Organisol "look" and "texture" [Re: 1972CudaV21] #1604146
04/26/14 12:23 PM
04/26/14 12:23 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Thanks Grizzly. I left the empty can at work so I'll have to read up about the UV protection tomorrow night when I go back. I hope it does though. I wonder, if it doesn't have very good UV protection, maybe I can low gloss clear coat it with something that does. Maybe i should have painted a piece and threw it outside for a while before I tried it on the spoiler lol.
Re: Organisol "look" and "texture" [Re: EL5 71] #1604147
04/28/14 11:17 AM
04/28/14 11:17 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Thanks everyone for your replies..
Totally Auto sent me another can of Organisol and this can worked out great. I was able to spray the whole taillamp panel. I sprayed a little closer than normal. Yes, I wanted the color and sheen of the original, but I wanted to cut down a wee bit on the "texture". I was able to accomplish this. The panel looks great and will much easier to wipe down.
Edward, nice local solution to the Organisol recreation...
Troy
Houston Mopar Connection Club
Re: Organisol "look" and "texture" [Re: hemi68charger] #1604148
04/28/14 12:03 PM
04/28/14 12:03 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
That looks MUCH better then the rough finish everyone seems to think is correct on the cars. Use the original stuff and you get original results. Even if it takes several tries! DAMHIK
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Organisol "look" and "texture" [Re: MOPARMIKE69] #1604149
04/28/14 07:56 PM
04/28/14 07:56 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Now that the spoiler has cured for a week or so, it does feel a bit gritty. I sprayed a small test area with Sems wheel and trim clear (semi-gloss) and it richened up the black color and smoothed out the texture feel a little. I'll probably take it into work this week, disassemble it and clear it just to see the results. Maybe even just shoot everything in low gloss black right over this coating to see how it looks. This is a scratched First Place spoiler I have (not my original) that I'm trying this stuff on. I like to see the results on an actual part instead of just a small test piece. Oh, and MEK seems to remove it without too much effort. Tail panel looks great Troy!! I like Totally's Organisol. Used it many many times. Hate the smell...but love the paint.
Re: Organisol "look" and "texture" [Re: EL5 71] #1604150
04/30/14 10:21 PM
04/30/14 10:21 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I recently had the V21 Hood Performance Treatment added to my Charger. After some contemplating using Badalson's Organasol or another paint, I chose to go with SEM's Hot Rod Black kit.
http://www.semproducts.com/hot-rod-black-kit/
My bud Bill (bill440rt) sprayed one overage coat & then 3 "dry spray" coats to create some texture.
Very happy with the results. This paint will be durable & easy to care for on a large area like my hood.
1MYTGTX
Re: Organisol "look" and "texture" [Re: 1MYTGTX] #1604151
04/30/14 10:24 PM
04/30/14 10:24 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
close up of texture when paint was dry for a day.
1MYTGTX
