130 tooth external balanced flywheel. #1603955
04/06/14 02:55 PM
04/06/14 02:55 PM
New York
jagrunt551 Offline OP
New York
I have a flywheel with casting #2284598 and a part number painted on that is #2264597. The flywheel has the 3 large holes drilled into it. Is this a correct 360 external flywheel? Thanks
Re: 130 tooth external balanced flywheel. [Re: jagrunt551] #1603956
04/06/14 03:15 PM
04/06/14 03:15 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
What diameter holes?
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 130 tooth external balanced flywheel. [Re: Dan Brewer] #1603957
04/06/14 03:18 PM
04/06/14 03:18 PM
New York
New York
If you mean the 3 large drilled holes , they are close to an inch .
Re: 130 tooth external balanced flywheel. [Re: jagrunt551] #1603958
04/06/14 07:57 PM
04/06/14 07:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The three holes on the 360 LA flywheel are 1 13/64" in diameter, the 360 Magnum holes are smaller. All 130-tooth flywheels have the same basic casting from '62-on.
Re: 130 tooth external balanced flywheel. [Re: John_Kunkel] #1603959
04/06/14 07:59 PM
04/06/14 07:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
LA and Magnum side-by-side. (Magnum on left)
Re: 130 tooth external balanced flywheel. [Re: John_Kunkel] #1603960
04/07/14 10:00 AM
04/07/14 10:00 AM
New York
New York
Ok Thanks for the help.
