Re: Power Cut Off switch Question.
[Re: rickraw]
#1599675
03/28/14 10:37 PM
03/28/14 10:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Does anyone have a fuse on their alt wire to the battery?
Yes.. I have a 100 amp on it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rickraw]
#1599678
03/29/14 01:14 AM
03/29/14 01:14 AM
MR_P_BODY
How many amp alt?
Its a 85A Denso ![](/ubbthreads/images/graemlins/wave.gif)
[Re: plycuda]
#1599679
03/29/14 01:34 AM
03/29/14 01:34 AM
Posts: 4,085 Mo.
racerx
Mo.
I have 150 and 300 amp
Where do uall purchase these fuses from?
[Re: racerx]
#1599680
03/29/14 01:43 AM
03/29/14 01:43 AM
MR_P_BODY
I get them from a local electrical ware house near me.. its a larger fuse like the mini flat bladed ones in the cars about 8 years ago... its just bigger with its own holder ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Just-a-dart]
#1599682
03/29/14 09:13 AM
03/29/14 09:13 AM
Posts: 4,085 Mo.
racerx
Mo.
Good car audio shops have them.
Thax. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Bigcube]
#1599683
03/29/14 11:44 AM
03/29/14 11:44 AM
Posts: 113 mi
rbj
mi
I don't like running the alternator wire to the battery because that wire will be hot all the time. I set mine up with a relay. I use a continuous duty relay, similar to a Ford starter relay. See attachment.
X2 ran mine same way , they run the constant duty on golf carts a lot got mine of eBay cheap and easy. Dvw recommend this idea and works well. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rbj]
#1599684
03/29/14 02:00 PM
03/29/14 02:00 PM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
Rather than running the alt power wire all the way back to the kill switch, I found it easier to run the field wire through a relay. I just ran a small 12 ga wire back to the switch for power, when the switch is off, car dies. I thought that was better than running the higher voltage the length of the car.
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: plycuda]
#1599686
03/29/14 03:46 PM
03/29/14 03:46 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Sorry to be an electrical idiot.... but that's what I am, and I want to be certain of what I think I'm seeing: We're talking about a 300 amp fuse on the pos. cable, and a 150 amp fuse on the neg, correct? Then, following Mike & Jim's outlines, a 100 amp fuse on the alternator wire, along with running that wire through the continuous duty relay....
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Am I straight on this?
[Re: RobX4406]
#1599691
03/29/14 05:20 PM
03/29/14 05:20 PM
StealthWedge67
Puyallup, WA
On a race car the way that s605 is wired is fine if you turn the master off.
Street car, if you leave the master on, the S605 will be a constant draw and drain the battery. It needs to be switched with something from a keyed source in the on position.
There's a minimum standard, then there are improvements.
Uhggg...... Why must there always be problems?! Are there relays available that would work like this, but not need to be switched? I generally break the master cutoff whenever I leave the car. But if I were to add this, I would want to do it correctly and not expose myself to potential dead battery issues. Wiring it all the way from the key switch seems like a hassle and lots of added wiring, which I don't want.
PS: sorry to hi-jack, but this is good info. and I think its relevent to the OP.
[Re: StealthWedge67]
#1599692
03/29/14 05:56 PM
03/29/14 05:56 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Find a wire that is hot when key is in run position and wire it to trigger the CD relay, pretty simple.
What's a 16ga wire weigh... not much and have it mirror route of the taillight wiring.
[Re: RobX4406]
#1599693
03/29/14 07:04 PM
03/29/14 07:04 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Rob is right as it is simple just make sure you use key on powered wire as I would not use a hot all the time wire for much of anything so you dont have a draw. I leave my switch on most of the time on the street and have no drain at all. But I run my alt output back to the battery side of the master switch and only use a solenoid for my starter cable. I do turn it off if I park the car where I cant see it all the time. Ron
#1599694
03/29/14 09:15 PM
03/29/14 09:15 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
300 amp on the starter cable and 150 on the alternator cable. not the neg cable
