? For those that run Drag Radials (rear) on the street
#1599325
03/27/14 09:05 PM
03/27/14 09:05 PM
Posts: 34,870 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
What is the go to tire for the front that most are using ?
I want something 26" tall 4.5 wide
Or close
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: ? For those that run Drag Radials (rear) on the street
[Re: n20mstr]
#1599338
03/27/14 11:48 PM
03/27/14 11:48 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Moroso ds2 on my car
On the street ?
Street, track, all the time, yes. Drives great
around here, they wouldn't live long
[Re: bigdad]
#1599339
03/28/14 12:35 AM
03/28/14 12:35 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
185/80R15 in either Hancook or Kumho on a 4" rim
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Jeremiah]
#1599341
03/28/14 12:59 AM
03/28/14 12:59 AM
Triple Threat
Renton Washington
I ran some Falkens for awhile, Flat spotted them when I spun the car. The car has Nexens or something on it now 165/85? They came from discount tire.
[Re: bigdad]
#1599343
03/28/14 09:04 AM
03/28/14 09:04 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I run the 28" tall M/T Sportsman front bias tire. Most of the 165R15 radials are only 25" tall. I think M/T has a 26" tall S/R radial front...they do not have anything taller than that in a radial skinny.
[Re: an8sec70cuda]
#1599344
03/28/14 10:34 AM
03/28/14 10:34 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I think for the street any good speed rated tire is better than a race tire and have only 1"-1 1/2" smaller dia. than the rear.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: bigdad]
#1599347
03/28/14 11:23 AM
03/28/14 11:23 AM
Posts: 12,011 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Tire Rack has a 195/70-15 Continental Vanco on clearance right now. They are about 26" tall but just a little wider than you spec'd. They are a D rated capacity tire rated to 65lbs air pressure. I run them and they hold the front of the car real well. A very good choice for $108, I think.
Master, again and still
[Re: DaveRS23]
#1599348
03/28/14 11:27 AM
03/28/14 11:27 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
195/65/15 Falkens. I was forced to buy them on drag week last year when I had a front tire failure. I like them better than the 165s I had on there. It looks a little better and drives slightly better.
68 Barracuda Formula S 340
[Re: 1967dartgt]
#1599350
03/28/14 12:12 PM
03/28/14 12:12 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
How do you guys feel about running these radials past there speed rating? All these tires are s speed rated so that's only good to 112mph.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 68LAR]
#1599351
03/28/14 12:15 PM
03/28/14 12:15 PM
BradH
I run a P215/75r15...
Same here, on 5" rims. IIRC, they're about 27" tall, but I can't recall the tread width. I have 275/60R15s on the back which are closer to 28" tall.
[Re: 1967dartgt]
#1599352
03/28/14 12:20 PM
03/28/14 12:20 PM
an8sec70cuda
I ran on the 165R15 tires for a long time and never had a problem. Lots of FAST cars around here are on them too. The speed rating thing is for sustained speeds, not for short bursts like in drag racing.
[Re: an8sec70cuda]
#1599356
03/28/14 05:13 PM
03/28/14 05:13 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My buddy would get on me for running the street tire rated at 112mph also and I told him the same thing thats its only for 10 seconds at a time not a long drive. Ron
[Re: 383man]
#1599357
03/28/14 06:07 PM
03/28/14 06:07 PM
Posts: 3,414 Toronto
mshred
Toronto
Running those non speed rated tires is an accident waiting to happen....just because it has happened to you or someone you know yet, doesn't mean it won't happen. Those tires were designed for lighter cars, sustained speeds or not. I am an idiot for ever running them for one season, which is why they came off very soon after so obviously you know my opinion
[Re: mshred]
#1599358
03/28/14 06:10 PM
03/28/14 06:10 PM
383man
Balt. Md
Running those non speed rated tires is an accident waiting to happen....just because it has not happened to you or someone you know yet, doesn't mean it won't happen.
Fixed it.
[Re: 383man]
#1599359
03/28/14 06:12 PM
03/28/14 06:12 PM
mshred
Toronto
Fixed it.
LOL thanks
Also, M&H makes a nice speed rated radial front runner that is imo better looking then the flame tread of the sportsman S/R radial...not sure what sizes in terms of height they have
[Re: SpareParts]
#1599362
03/28/14 06:18 PM
03/28/14 06:18 PM
Posts: 68 Detroit, MI
RawnDart
Detroit, MI
MT sportsman fronts
Same here. 26x6
[Re: RawnDart]
#1599363
03/28/14 06:32 PM
03/28/14 06:32 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
I run the MT Sportsman S/T Radials. They look like BFG radial T/A's. They are a good tire but I don't know if they come in a size as small as you are looking for.
I like to get a front tire as close to as tall as the rear as possible. I think it help weight transfer and it does help with ground clearance.
[Re: RawnDart]
#1599364
03/28/14 06:35 PM
03/28/14 06:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
MT sportsman fronts
Same here. 26x6
I'm looking at the sportsman for the spare set of tires for racing.. I like my road racing type tire for the street.. they handle very well but are a BIT wide for the track
[Re: mshred]
#1599365
03/28/14 09:59 PM
03/28/14 09:59 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
The radials in the link below are the ones I am talking about...I think street driving on the cheapy tires is more dangerous then racing them, thats just my opinion though
http://www.mandhtires.com/M-H-Front-Runner#.UzXYfvldVgk
My post above has a direct link to the 26" radial front runners that are on my Charger. The work just fine and are ok in a light rain if you are respectful and have the brake proportion set up correctly.
[Re: Jeremiah]
#1599366
03/28/14 10:07 PM
03/28/14 10:07 PM
mshred
Toronto
Didn't even notice that sorry lol...Yea apparently they are a pretty good tire. I would rather run those then the cheapies, a little more peace of mind I feel like
[Re: Jeremiah]
#1599368
03/28/14 10:56 PM
03/28/14 10:56 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use a 205/75/15 on a 4" wheel.Works great.The tires are Firestone from Tires Plus.
[Re: Chris2581]
#1599369
03/28/14 11:28 PM
03/28/14 11:28 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Check out the Vredestein Sprint from Coker. They have a 165/15, basically an old sports car/VW tire with a vintage appearance. Kind of looks a Sportsman front but it's a radial. I think they have a decent speed rating. About $115 each, not a bad price. A cheaper alternative to a Michelin XZX. http://www.cokertire.com/165hr15-vredestein-sprint-blackwall-tire.html
'71 Duster '17 Ram 1500
[Re: Jeremiah]
#1599370
03/28/14 11:56 PM
03/28/14 11:56 PM
1967dartgt
Hilltown Pa
proportion set
I have been looking at those.
[Re: 1967dartgt]
#1599371
03/29/14 12:12 AM
03/29/14 12:12 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am running Lemans 165 R15 and would like to go to a slightly taller MT Sportsman Front tire. Does anybody know which one I should buy. THANKS....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 1967dartgt]
#1599374
03/29/14 12:34 AM
03/29/14 12:34 AM
D-50
North, Alabama
Thanks 1967DartGT, I have been having a problem Red lighting and thought going to a taller tire might help.
