70-71 Elastomeric Rubber Bumpers #1598871
03/26/14 08:56 PM
03/26/14 08:56 PM
Mechanicsburg, PA
LemonTwiist Offline OP
Mechanicsburg, PA
Can someone tell me what the difference is between 70 and 71 Rubber bumpers for a Cuda?
Re: 70-71 Elastomeric Rubber Bumpers [Re: LemonTwiist] #1598872
03/26/14 09:01 PM
03/26/14 09:01 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
The bottom is wider at the bottom where the opening is for the lower valance on the 70 and narrower on the 71 as the opening is not as wide. I hope I dont have it backwards.
Re: 70-71 Elastomeric Rubber Bumpers [Re: magiccuda] #1598873
03/26/14 09:21 PM
03/26/14 09:21 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Drew... Here's the pics to confirm what magiccuda refered to...
70......
Here's the 71...... ... And lastely a 71 with a 70 bumper installed... By the way, the painted galvanizing trick you posted in another thread works like a charm... Hope to see you out and about this summer...
Re: 70-71 Elastomeric Rubber Bumpers [Re: magiccuda] #1598874
03/26/14 09:28 PM
03/26/14 09:28 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
To my knowledge the rear bumper is the same.
The front bumpers are different. This is since the valence insert opening is different. The bumper matches the valence.
See marked up pictures from others.
This picture shows a 70 bumper on a 71.
Re: 70-71 Elastomeric Rubber Bumpers [Re: larry4406] #1598875
03/26/14 09:29 PM
03/26/14 09:29 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Here is a 71
Re: 70-71 Elastomeric Rubber Bumpers [Re: larry4406] #1598876
03/26/14 09:39 PM
03/26/14 09:39 PM
Mechanicsburg, PA
Mechanicsburg, PA
OK Thanks guys Much appreciated
Re: 70-71 Elastomeric Rubber Bumpers [Re: larry4406] #1598877
03/26/14 10:09 PM
03/26/14 10:09 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Here is a 71
Wheres that boy's core support black out, wow that white is bright behind the grille
MLR426
Re: 70-71 Elastomeric Rubber Bumpers [Re: MLR426] #1598878
03/29/14 05:25 PM
03/29/14 05:25 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I agree...
