440 piston question #1597544
03/23/14 07:20 PM
03/23/14 07:20 PM
Indiana
sipepuller Offline OP
Indiana
I just got a set of pistons with a set of rods I wanted and I'm trying to figure out what the pistons are. All they have is on inside say DRP 50. And has this number to 28235. Any ideas ??
Re: 440 piston question [Re: sipepuller] #1597545
03/23/14 09:22 PM
03/23/14 09:22 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Pictures ? measure the pin height ?
If they are flat top with no valve reliefs they are more than likely a smog motor replacement .
Re: 440 piston question [Re: JohnRR] #1597546
03/24/14 09:24 PM
03/24/14 09:24 PM
Indiana
Indiana
No there not smog replacement pistons there on aluminum rods I wanted I tink there diamond racing pistons Looks like the measure the same as my .60 over dome pistons I have already I emailed diamond racing the numbers and stuff to see if the can tell me what they are for sure
Re: 440 piston question [Re: sipepuller] #1597547
03/24/14 10:59 PM
03/24/14 10:59 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
is that 28235 engraved in the top of the piston ? Pictures ?? do they have valve reliefs , your poor description is obviously not getting you any answers.
Re: 440 piston question [Re: JohnRR] #1597548
03/25/14 12:21 AM
03/25/14 12:21 AM
pistons are already hung on the rods correct? Set a piston top down on your kitchen table & set a round (say 1/4") rod horizontle in thru the pin on the top (now the bottom (floor) since it is inverted) & with the rod extended out measure from the table up to it (dimention A). subtract the rod (ie 1/4") thickness from that to get dimention B then subtract .150" (wall thickness) from dimention B to get C then add in .5045" (1/2 of pin OD) to C to get the compression height.
