Existing roof skin removal from a 69 RR pillar coupe. #1596259
03/21/14 05:18 PM
03/21/14 05:18 PM
Surrey, British Columbia
TseTse Runner Offline OP
What "tricks" are there when one wants to remove the roof skin? I have all of the spot welds cut out and now need to get some help \ ideas on how to overcome the "glue" which holds the roof skin to the ribs.
Thanks.
Re: Existing roof skin removal from a 69 RR pillar coupe. [Re: TseTse Runner] #1596260
03/21/14 08:45 PM
03/21/14 08:45 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
On the sealer spots'you can use a hand held torch.Propane is fine.Put some UP pressure with a small pry bar or screw driver and it will release.
Re: Existing roof skin removal from a 69 RR pillar coupe. [Re: 5carguy] #1596261
03/21/14 09:27 PM
03/21/14 09:27 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Get a couple seam buster blades and work your way round the roof.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
