Anybody measure KB hyper pistons? Typical Undersize?
#1592829
03/14/14 02:28 PM
03/14/14 02:28 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Typically...how much under standard bore sizes is a KB hyper piston typically? I know you have to measure the actual pistons used, but do they usually run .0015 or ? under the std bore sizes?(Std, +.030, +,.040, +.060, etc).
Is there a rule of thumb?
Re: Anybody measure KB hyper pistons? Typical Undersize?
[Re: Quicksilver440]
#1592830
03/14/14 02:31 PM
03/14/14 02:31 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Most pistons are under the size of the bores, not as big as the bore so the machine shops have to make the bore over size I've never ran the KB hypers, I don't like any cast pistons I have ran and used thier forged pistons They had the clearances built into the pistons
[Re: Oyvind Mopar]
#1592832
03/14/14 03:27 PM
03/14/14 03:27 PM
Posts: 2,629 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Just measured some Wednesday night. They were all .002 under. This is much better than the last 2 brands I measured which had .0015 variance between them.
2011 Drag Pak Challenger
#1592838
03/17/14 12:45 AM
03/17/14 12:45 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
They are tight because the pistons dont grow much. But the clearance is determined by bore diameter and intended performance. But still its a very tight perimeter.
.0015 to .0055 from small bore NA to large bore supercharged.
The clearance is measured at the skirt parallel to the balance pad height.
Whats even more important IMO, is the top ring gap. As it is closer to the top of the piston vs other type pistons that it requires extra top ring gap to prevent butting of the ends.
Example, NA 4.36 bore race gasoline motor = .033 top ring gap.
