Re: Erson Cams Quality Discussion
[Re: ErsonCamShop]
#1592477
07/29/14 05:08 PM
07/29/14 05:08 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Just bought one for a 265 Chevy. I'll let you know.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: dfsmopars]
#1592478
07/29/14 05:28 PM
07/29/14 05:28 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would like to see options for a firing order swap, especially for a Hemi...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: rt66jim]
#1592482
07/31/14 11:15 AM
07/31/14 11:15 AM
Posts: 30 Louisville, KY USA
ErsonCamShop
Louisville, KY USA
Do you have any blank cam cores for a 48* block with standard cam bearings?
I would need to know what lobe sep core you're looking for. We have several different standard journal hemi cores in stock. To answer your question more specifically, you should probably speak with Eric Bolander. He is our cam consultant. He has a full list of our core inventory, journal diameters and lobe profiles. If you would like his contact information, PM me. I'll be glad to get that to you. Thanks Russ
[Re: SomeCarGuy]
#1592483
07/31/14 11:18 AM
07/31/14 11:18 AM
ErsonCamShop
Louisville, KY USA
Web site needs more bandwidth!
The new website is in the works. Hopefully we'll have it operational in the next few weeks. If anybody needs contact information, please private message me. I'll be glad to get you our cam consultants direct phone number. Thanks Russ
[Re: ErsonCamShop]
#1592490
03/06/15 06:54 PM
03/06/15 06:54 PM
Posts: 1,239 Chicago, IL
PLUM_72
Chicago, IL
What no discussion around a cam taking advantage of Chrysler's large .904" lifter diameter?
Hughes Engines makes some good points around the .904 lifter and cam design. Not everyone is a Hughes fan, but they do make a good argument here.
1972 Dodge Challenger
[Re: PLUM_72]
#1592491
03/07/15 02:20 PM
03/07/15 02:20 PM
Posts: 905 SD
zrxkawboy
SD
This summer, I plan to rebuild the 230 flathead 6 in my '57 Plymouth. I noticed earlier in the thread that you re-grind cams...I will probably be checking with you for pricing. Do you also re-grind the lifters that are in these motors? Thanks
It's Swifty! Swifty, you toad sucker!
[Re: PLUM_72]
#1592492
03/07/15 04:50 PM
03/07/15 04:50 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
It seems most of the flat tappet cams used on our Mopars are the high rate of lift type from Hughes Engines, Lunati Voodoo series, and Comp XE series of cams. It's nice you offer the 3-bolt version of the cams too. Went to your on-line catalog, and only small block cams are listed? http://www.pbm-erson.com/Catalog/Erson/C...6&criteria=
