Re: Erson Cams Quality Discussion
[Re: Rhinodart]
#1592456
03/27/14 09:54 AM
03/27/14 09:54 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
I P mailed for a catalog.It was here in about 2 days.Im not ready for a cam right now but they have some nice looking grinds.I will definetly look to Erson when its time for a new bump stick.Rocky
Chrysler Firepower
[Re: 71birdJ68]
#1592457
03/27/14 11:13 AM
03/27/14 11:13 AM
Posts: 30 Louisville, KY USA
ErsonCamShop
Louisville, KY USA
Where on the web site do it show anything about Mopar cams? I tried to look, maybe I'm just blind.
Our website is under construction. We don't have half the combinations offered on the site yet. But we'll be glad to send you a catalog. And if you don't see the combination you want listed, our master profile list is in the back of the catalog and we'll be glad to custom grind you any combination. If you'll PM us your address we'll make sure a catalog gets sent to you. Thanks Russ
[Re: dogdays]
#1592459
03/27/14 06:48 PM
03/27/14 06:48 PM
ErsonCamShop
Louisville, KY USA
I have a TQ30H that's going into my $500 77 ford pickup, 400 engine. But first I have to check the retainer-to-guide clearance and install new springs that won't coil bind at the higher lift.
Looking for specs on the cam, I found at least two different grinds. Mine appears to be the older one, single pattern I think it's 218 @50 with 110LSA and over a half-inch lift.
Should run really strong, it's a long distance machine with 3.00 gears.
Back to the multi-pattern grind, I think Comp might have left some on the table with their selection. Have you looked into different phasing for the inner and outer lobes? Like a wider LSA on the outers, for example?
R.
Along with the four-pattern cam, we change the lobe sep on them regularly to help with the overlap as well as changing the duration. A lot of times those figures are taken into account depending on what the flow figures are on the cylinder heads with the manifold installed. As far as your cam for the 400, Part No. E220221 Grind: TQ 30 H 110+4 Lobe Seperation Angle Overlap: 90.00 Intake Opens: 49.00 Exhaust Closes: 41.00 Intake Closes: 81.00 Exhaust Opens: 89.00 Running Clearance: 0.000 0.000 [Hot] Valve Lift (Int / Exh): 0.536 0.536 Duration (Int / Exh): 310 310 Checking Figures @ .050" Tappet Rise Overlap: 6.00 Intake Opens: 7.00 Exhaust Closes: -1.00 Intake Closes: 39.00 Exhaust Opens: 47.00 Duration Intake: 226.0 Duration Exhaust: 226.0 Lobe Lift Intake: 0.310 Lobe Lift Exhaust: 0.310 Intake Center Line: 106 Rocker Arm Ratio: 1.73 CAM NO. SPECIAL NOTES XXXXXX CATALOG GRIND
This is our cam card on it. Thanks Russ
[Re: Yellow Fever]
#1592464
05/04/14 01:57 AM
05/04/14 01:57 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Wow, big improvement at the Erson site. Well done.
Leave the gun.......take the Cannoli's....Mike
[Re: dart4forte]
#1592466
05/06/14 12:43 PM
05/06/14 12:43 PM
ErsonCamShop
Louisville, KY USA
Last Erson cam I ran was back in the old Super Shop days.
It's funny you bring up Super Shops days. My first tunnel ram and two four barrels came from there in the mid 80s. Working on bringing pride and integrity back to the Erson name. I want our customers to know when they order an Erson cam it'll be made to spec. All your feedback has been very appreciated. We're still working on the website. Please keep sending us your feedback, and we'll keep growing in the direction you need us to go. Thanks Russ
[Re: dan9]
#1592468
05/08/14 01:57 PM
05/08/14 01:57 PM
ErsonCamShop
Louisville, KY USA
Years ago i bought a Chet Herbert cam. On the phone he said it didn't need broken-in because it was Parkerized. Is that true or possible? If so it would be a great thing, it seems even the pros wipe out cams after a rebuild.
Parcorizing a cam gives it the surface to accept antiwear agents, normally known as zinc. If you're running a flat tappet cam, you MUST run oil with zinc in it or a zinc oil additive, and you must break the cam in the same way. Today's over the counter oils do not have zinc in them. The most popular oil I know of people using is diesel oil, or Rotella if they're not purchasing a special oil like Joe Gibbs or Brad Penn. Hope this helps. Thanks Russ
[Re: ErsonCamShop]
#1592470
05/28/14 08:09 PM
05/28/14 08:09 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
I just pulled this cam out of my 440: T030H 867S7 111 682 A Can you tell me the specs? Thank you!!!!
Admiration For Multiple Carburetor Vehicles...
[Re: Stewpar]
#1592471
05/30/14 04:20 PM
05/30/14 04:20 PM
ErsonCamShop
Louisville, KY USA
Thank you!!!!
Did you get your specs that I emailed you? Thanks Russ
[Re: MLR426]
#1592473
06/04/14 11:20 AM
06/04/14 11:20 AM
ErsonCamShop
Louisville, KY USA
Hello Russ just checking on the post to see whats happening.
MLR426 Martin
Thanks for the message, Martin. Give me a call some time, I need to ask you about some self adhesive sanding discs for one of our sanders. If anyone has any cam questions or concerns, please feel free to ask. Thanks Russ
