Re: CHARLIES OIL PAN [Re: Al_Alguire] #1592128
03/13/14 05:49 PM
03/13/14 05:49 PM
AndyF Online content
AndyF  Online Content
The effectiveness of the kick out might depend on the stroke. I'm running a 4.15 stroke in my 514 so the rotating assembly swings down below the oil pan rails. I use a duck bill type of scraper that aims the windage into the kickout. No doubt that there is hp in this area but it does take work to find it and the work isn't much fun. Changing oil pans on the dyno is real grunt work.
Re: CHARLIES OIL PAN [Re: AndyF] #1592129
03/13/14 07:48 PM
03/13/14 07:48 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Ive used a few,have asmall block version onmy 408. Ilike it, Good clearance, nothing thats the pans fault as for leaks.
I like it.
Re: CHARLIES OIL PAN [Re: Al_Alguire] #1592130
03/13/14 10:04 PM
03/13/14 10:04 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Chris I ran that pan for years and NEVER ha d a leak. Also in reply to the no HP gain with the kickout I will call BS as well. We ran mine on the dyno when I first bought one. We made 23 more HP with the side kickout than we did with the milodon dragster style pan. So my experience is quit e a bit different than posted here. We have since moved on to a different pan builder. But I still feel this is one area many Mopar guys are missing the boat.
Totally agree….gotta call BS myself….23HP switching to a kickout pan on a bb mopar….absolute BS! What else did you change prior to that dyno pull?
Switching from a wet sump to a dry sump only yields 25 – 30 hp on average with virtually any brand. (bigger the arm - bigger the gain)
For those who still have an open mind, consider that a kickout is only a reversion devise that prevents the windage from climbing the right side of the block, making the windage even worse, increasing the froth and overcoming the right bank of piston rings….which could also contribute to detonation, but don’t give a kickout pan all of the credit for preventing that. Some of the other posters’ above have it right in that a properly shaped and located scraper will help a noticeable amount…on virtually any brand of engine.
Using a Chrysler bb with a 4.5 arm, std pin diameter and aluminum rods the reciprocating assembly breaches the pan rail about 3 inches. With that as a fairly extreme example, the crank is only pitching the oil from ~185º through ~215 of crankshaft arc allowing the kickout to trap windage……now compare that to a BB gm, the crankshaft axis and the oil pan rail are in the same plane….using a kickout on that design will provide trapping benefit from ~185º to ~255º in crankshaft arc. The bb gm will only see about 3 – 5 hp……so 23hp on a bb Chrysler? Me thinks someone has been vacationing in Colorado
....and for those special individuals, dont compare a kickout pan designed for windage reduction to a kickout pan designed for ground clearance
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592131
05/04/14 12:54 AM
05/04/14 12:54 AM
north carolina
W
wideopen231 Offline
wideopen231  Offline
W
north carolina
HI,
New to forum. Found site and this thread by research for hemi pan I am building for my FED. Having hemi in bracket racing has turned into a make most everything adventure,which I happen to enjoy tons.
I have decided to go with kickout on pan and have been told by numerous others that kickout pan on skirted block is useless. Seems in their mind it only works on V blocks I guess Y shaped block eliminates any windage in crank case. I read most of thread before joining. Seems mixed results here I di notice Al who is alos over at drr. Have always found him to be pretty straight Shooter. He did state he found 20 some hp gain with pan.About same as most Chevy guys say they pickup. Funny hum? While 20 is no big thing it does add up and thats not bad for a little pouch on side of pan.
I have TFX-92 block and finding a pan with kickout has proven difficult.Did run across cpl things on Charlie's. Mostly good reviews. Since I was already building pan and had added a starter pocket on left,mounting under block not std hemi position. I figured I would just add kickout to right side and rework baffles some,while at it adding scraper to direct windage better ane thought about making some sort of filler piece in front to limit there and add beter controll under braking.I am now looking at the lower sump in rear that was mentioned in thread.
So far very informative forum and I have been here maybe hour. Thanks guys and maybe I can give back some info to others.
Spent ten years running TA/FC and TA/D .also spent cpl retirement plans for most.Got to hate money to do this right?
Re: CHARLIES OIL PAN [Re: wideopen231] #1592132
05/05/14 04:17 AM
05/05/14 04:17 AM
Arizona
Chris'sBarracuda Offline OP
Arizona
UPDATE..
I put the Charlies oil pan in question on my Engine and it helped my oil pressure situation..
Didn't go to zero at the end of the run..
Lowest was 40 psi hot.. after run.. And.. Was 0-20 before with the old pan..
Did it make more power.?? Not sure yet.. Only raced it in really bad air, but it ran better than expected...
I'll know more when I get to run in conditions that I have data for..
Anyway, I like the pan and I got it from a member (Doug-- d7cook) here at a really good price..
Chris..
Re: CHARLIES OIL PAN [Re: Jerry Kathe] #1592133
05/05/14 11:53 AM
05/05/14 11:53 AM
north carolina
W
wideopen231 Offline
wideopen231  Offline
W
north carolina
Far from expert here. Especailly on BB mopars gains.I do know there are lots of guys who would argue the gains on BBC.Most backed by dyno results.One would be R-M,seems they claim gains of 20 plus hp also.I agree BB mopar with skirted block will probably not gains as much,but I do thing theres gains to be made. After all the debate I plan on soing a oil pan swap on car after I get basic tuneup and cars consistent enough to verify results. Don't be holding breath on them since I'm still building car and have been for way too long.We do except donations at Chris needs to race soon.LOL
Re: CHARLIES OIL PAN [Re: wideopen231] #1592134
05/07/14 02:34 AM
05/07/14 02:34 AM
Arizona
Arizona
I always need to race..
Chris..
Re: CHARLIES OIL PAN [Re: wideopen231] #1592135
05/07/14 05:32 AM
05/07/14 05:32 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Some of the 3.480" stroke Mopar Hemi Pro Stocks in the early 70's had a large kickout on the right side.
I know of a 3.388" stroke 383 in NHRA Super Stock that ran pretty quick and had a large kick out on the right side.
Re: CHARLIES OIL PAN [Re: LSP] #1592136
05/07/14 01:03 PM
05/07/14 01:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hmmm...One of my skirted blocks..Someone was thinking out of the box developing this set up.
FWIW when we went ot a GOOD pan and picked up power it was in a low deck motor not an RB..
Re: CHARLIES OIL PAN [Re: Al_Alguire] #1592137
05/07/14 01:59 PM
05/07/14 01:59 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
I invented new cuss words when I had that motor......
Re: CHARLIES OIL PAN [Re: B1CUDA] #1592138
05/07/14 02:20 PM
05/07/14 02:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You and me both..In fact I just invented a couple new ones when I got the last bill from Nickens
Re: CHARLIES OIL PAN [Re: Al_Alguire] #1592139
05/07/14 02:37 PM
05/07/14 02:37 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
IMO the biggest problem with that pan is the "one way screen". Get one with a scraper or put in a regular windage tray, that screen is a POS.
Re: CHARLIES OIL PAN [Re: camastomcat] #1592140
05/08/14 10:32 AM
05/08/14 10:32 AM
Out West
408strokerdart Offline
Out West
After the last screwing I got from Charlie himself, I declare that I will never have another Charlies pan on anything I own.
My last experience.....lets just say it wasn't good. Could have gotten a lot better pan for what I had to invest in fixing my new Charlies pan. If you think a Charlies pan is nice then you must have never had a Williams or Billet Fab. I waited a lifetime to finally get my Williams pan, but it did fit out of the box.
Re: CHARLIES OIL PAN [Re: 408strokerdart] #1592141
05/08/14 10:26 PM
05/08/14 10:26 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I sent Charlie a drawing last year for a double kickout wet sump pan, and he nailed it in 3 weeks. Very pleased with the quality, fit, and the accuracy to the drawing. If it was off dimensionally even slightly I was going to have clearance issues with the headers, water drains, starter, etc..
Re: CHARLIES OIL PAN [Re: Al_Alguire] #1592142
06/27/14 09:53 AM
06/27/14 09:53 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
How much "kick out" is recommended? How deep? etc...
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: CHARLIES OIL PAN [Re: 408strokerdart] #1592143
06/28/14 07:23 PM
06/28/14 07:23 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Which "Williams" do you mean. and what makes it better than your Charlie's pan?? I am in the market for a new wet sump pan for my low deck KB block and looking for ideas!!!
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: CHARLIES OIL PAN [Re: cudabin] #1592144
06/28/14 08:08 PM
06/28/14 08:08 PM
gregsdart Offline
gregsdart  Offline
As far as gains go on a skirted block, the long skirt HOLDS the oil more so than a BBC, I bet. A 426 Hemi was tested way back in the day and could hold 8 quarts wrapped around the crank at 8,000 rpm. That should say something. So I don't buy the argument of less degrees to lose the oil into the side bucket.
Re: CHARLIES OIL PAN [Re: 1320Dart] #1592145
06/28/14 08:14 PM
06/28/14 08:14 PM
Arizona
Arizona
I would think any side kickout has to help some..
As i posted earlier, this new Charlie's pan definitely helped my oil pressure loss at the top end..
Went from 0-20 psi to 40 psi steady after shutdown.. I have it on video
for proof to me..
BTW.. I had a nice Williams pan before, but it was too deep.. Couldn't use it.
Chris..
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592146
06/29/14 12:53 AM
06/29/14 12:53 AM
you have a PM
