CHARLIES OIL PAN #1592108
03/12/14 09:25 PM
03/12/14 09:25 PM
Arizona
Chris'sBarracuda Offline OP
Arizona
Has anyone used this oil pan..??
Thinking of getting this one here..
http://chucker54.stores.yahoo.net/brbsupcomtub.html
Thanks..
Chris..
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592109
03/12/14 09:28 PM
03/12/14 09:28 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Leaks like a sieve...If you can't weld on aluminum, I would avoid their crap...
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592110
03/12/14 09:28 PM
03/12/14 09:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have two of them and love them both. The one I had on my 572 has a little kick-out on it. If you want some pictures let me know.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: CHARLIES OIL PAN [Re: pittsburghracer] #1592111
03/12/14 09:29 PM
03/12/14 09:29 PM
Arizona
Arizona
Yes.. Please..
Chris..
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592112
03/12/14 09:35 PM
03/12/14 09:35 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i have one never had a problem with it
Re: CHARLIES OIL PAN [Re: ro23car] #1592113
03/12/14 09:41 PM
03/12/14 09:41 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
IMO it is a good pan for the money. We have used them in the past and they are WAY better than the Milodon stuff.
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592114
03/12/14 09:46 PM
03/12/14 09:46 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Charlie makes some nice, reasonably priced stuff
I have his original 10 quart Super Stock pan with the center link tube on my car. He cam over to the shop so he could fit it up, took his measurements and said "Thanks, the pan is yours"
Chris don't forget about some quality (Superformance) oil pan gaskets with your order
http://search.store.yahoo.net/chucker54/...erpackages.html
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592115
03/12/14 10:08 PM
03/12/14 10:08 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
FYI this was from just a week or so ago...I posted some pics of mine I just bought.
https://board.moparts.org/ubbthreads/show...e=2#Post8062336
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592116
03/12/14 10:56 PM
03/12/14 10:56 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Good products, good prices.
This could just be considered an opinion.....but a kick out pan on a long skirt block provides no measurable gain, the oil slung from the crank and rods are too far below the tangent for the kick out to work like a brand x....but it looks cool....
Re: CHARLIES OIL PAN [Re: Jerry Kathe] #1592117
03/12/14 10:59 PM
03/12/14 10:59 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Agreed, however it does add oil capacity without sacrificing ground clearance.
I assume that's why Charlie designed it in there.
Re: CHARLIES OIL PAN [Re: roadhazard] #1592118
03/12/14 11:10 PM
03/12/14 11:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I had to massage a few pan holes. Other than that it fit prefect. Doesn't leak a drop. The price was very fair. Mine is a custom piece with a moved tie rod hole. Came with a screen and has plenty of baffling. t's the third one I've bought for various motors. never an issue.
Doug
Re: CHARLIES OIL PAN [Re: dvw] #1592119
03/12/14 11:52 PM
03/12/14 11:52 PM
PA.
"Little"John
"Little"John
PA.
Regular oil pan.
Kick out pan.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CHARLIES OIL PAN [Re: pittsburghracer] #1592120
03/13/14 12:01 AM
03/13/14 12:01 AM
PA.
"Little"John
"Little"John
PA.
One thing to really watch out when using this pan as it about drove me nuts with an oil leak was the flanges are really heavy duty on these pans and wider than a stock type pan. Well on my Keith Black block the main stud extended a little lower that on a stock block and the pan flange was catching on the stud and not letting the pan bottom out. You couldn't see it in the car and I thought it was a rear main seal. IT WASN'T. Its a simple fix as all I had to do was remove a few threads but like I said finding it wasn't easy.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CHARLIES OIL PAN [Re: Forest] #1592121
03/13/14 01:51 AM
03/13/14 01:51 AM
Arizona
Arizona
Was that the Mancini (Charlies) MRE159 pan you ordered in those pics.??
Thanks, Chris..
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592122
03/13/14 02:23 AM
03/13/14 02:23 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Yes, thought you might like to know that the height was different than what Mancini advertises...
Re: CHARLIES OIL PAN [Re: roadhazard] #1592123
03/13/14 02:42 AM
03/13/14 02:42 AM
AndyF Offline
AndyF  Offline
I've had Charlie build me several custom pans. We keep going bigger and bigger on both the kickout and the depth and keep picking up power.
Re: CHARLIES OIL PAN [Re: pittsburghracer] #1592124
03/13/14 03:32 AM
03/13/14 03:32 AM
Arizona
Arizona
Regular oil pan.
So John..
Missing 4 pan bolts on the passenger side doesn't create a leak.??
Chris..
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592125
03/13/14 09:12 AM
03/13/14 09:12 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use Charlies pans and use a lot of them.The dragster style like you show,but with full tray and scraper instead of screen.Usually we have to tweak a few bolt holes and relieve some heavely welded areas at the corners.Great prices and service.
Re: CHARLIES OIL PAN [Re: Chris'sBarracuda] #1592126
03/13/14 10:02 AM
03/13/14 10:02 AM
PA.
"Little"John
"Little"John
PA.
Regular oil pan.
So John..
Chris..
No leaks but on that pan those two bolts are kind of a pain as they go up thru a couple of plugs in the bottom of the pan. I ground a socket to fit up thru the tube to tighten the pan head (flange head) nuts. all the bolts are studded and I use a gasket and "Right Stuff" sealer. Like I said above these pans have a flange that's about 1/4 inch thick and you can really crank them down. Tom Hemphile ordered that pan for me many years ago and I picked up the kick out pan on ebay I think.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CHARLIES OIL PAN [Re: pittsburghracer] #1592127
03/13/14 01:55 PM
03/13/14 01:55 PM
Las Vegas
Las Vegas
Chris I ran that pan for years and NEVER ha d a leak. Also in reply to the no HP gain with the kickout I will call BS as well. We ran mine on the dyno when I first bought one. We made 23 more HP with the side kickout than we did with the milodon dragster style pan. So my experience is quit e a bit different than posted here. We have since moved on to a different pan builder. But I still feel this is one area many Mopar guys are missing the boat.
