small valve stem tubes for 28 x 11 DOT tires #1591686
03/11/14 10:29 PM
03/11/14 10:29 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Anyone make tubes with a small valve stem bolt style, for 28 x 11 slicks or DOT tires? My rims, steel for NSS will not take the larger bolt in style stems on the tubes I bought, MT natural rubber. Need to find a different small stem tube or use drag radials
Using 15x8 steel wheels on my 67 Belvedere BTW. I want to keep the steel look and hope I just di nto get hosed on the rims I had made.
Thanks.
Re: small valve stem tubes for 28 x 11 DOT tires [Re: sawdust] #1591687
03/11/14 10:33 PM
03/11/14 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Call Harlow Tire
Re: small valve stem tubes for 28 x 11 DOT tires [Re: MR_P_BODY] #1591688
03/11/14 11:33 PM
03/11/14 11:33 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Thanks, I will give them a call. Hopefully they have a better idea than the tire shop we have here.
Not slamming my guys, they have been in the business for over 80 years and their manager was one of my dads metal shop students in the early 60's so he is kind of in the know with over 40 years in the tire biz.
Thanks again this car has been frustrating at every step to make it right as I am anal.
Next build will hopefully be easier, a FAST stocker
Re: small valve stem tubes for 28 x 11 DOT tires [Re: sawdust] #1591689
03/12/14 10:10 AM
03/12/14 10:10 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Did ya call Creamery?
Re: small valve stem tubes for 28 x 11 DOT tires [Re: sawdust] #1591690
03/12/14 03:29 PM
03/12/14 03:29 PM
The easeast way to resolve your problem is to enlarge the hole for the stems I've had to do that on steel and race aluminum rims for race tubes I don't run tubes anymore so I use the all metal valve stems now
