Re: Neon rings [Re: gdonovan] #1590335
03/10/14 11:23 AM
03/10/14 11:23 AM
dogdays Offline
dogdays  Offline
Actually, moly rings require less surface roughness to seat. And to the OP, the factory moly rings are CERTAINLY a factor in why the engine has lasted this long. They are easier on the cylinder walls than plain cast iron rings, much easier than chrome.
File fitting is great, but you still have to deal with the taper in the cylinder. If you have 0.007" taper, for example, it will be on the top end of ring travel. But on the bottom end of ring travel it may be close to standard size. So if you gap the rings properly at the top, they may have problems a the bottom of the stroke.
Total Seal rings in standard size sound like a good crutch for this engine.
R.
Re: Neon rings [Re: DaveRS23] #1590336
03/10/14 11:59 AM
03/10/14 11:59 AM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I'll go over to Neons.org and see what they say. It's more entraining here, and I on here all the time, so this was my first stop.
Re: Neon rings [Re: 71birdJ68] #1590337
03/10/14 12:36 PM
03/10/14 12:36 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
As a retired Chrysler tech, I'd say either slap it together as cheap as possible or replace with a used engine.
The rods are a ticking time bomb, I'm amazed they have gone this far. Just a matter of time before they let go from fatigue and its best to have as little as possible invested when they do.
If I recall correct, Chrysler would sell pistons only with rods attached, there was a reason for it...
"I think its got a hemi"
Re: Neon rings [Re: gdonovan] #1590338
03/10/14 09:41 PM
03/10/14 09:41 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I was thinking that the reason the "rings" were so expensive from Mopar was because it was actually the piston, rings, and rod. But I am not sure anymore. It's been a long time since I priced any of these parts.
Master, again and still
Re: Neon rings [Re: DaveRS23] #1590339
03/10/14 10:32 PM
03/10/14 10:32 PM
Morristown Tn.
Morristown Tn.
$125 just for the rings, per hole.
Re: Neon rings [Re: 71birdJ68] #1590340
03/10/14 10:44 PM
03/10/14 10:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
ROCKAUTO.COM
Sealed Power moly $75 for a set, of four piston's worth, not one hole and those are the expensive sets.
Don't be the exception.
Re: Neon rings [Re: Supercuda] #1590341
03/10/14 10:46 PM
03/10/14 10:46 PM
Morristown Tn.
Morristown Tn.
Yes, thanks, I noticed them earlier today. I think that is what I might do.
Re: Neon rings [Re: 71birdJ68] #1590342
03/10/14 11:07 PM
03/10/14 11:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Some thing isn't right on your pricing from Mopar. There is no way in hell a set of rings would cost $125 per cylinder.
Mopar parts America pricing.
ENGINE / PISTONS, RINGS & BEARINGS / PISTONS, RINGS & BEARINGS / PISTON RING SET
PISTON RING SET Neon 2.0L, SOHC
Complete Set Of Rings For 4 Pistons.
MSRP Core ? Online Price
$170.00 $0.00 $122.40
Re: Neon rings [Re: stumpy] #1590343
03/10/14 11:24 PM
03/10/14 11:24 PM
Morristown Tn.
Morristown Tn.
Ok, I'll look at that again. My dealer was the one that said per cylinder.
