A-Body Door Window Slides #1588182
03/04/14 11:13 PM
03/04/14 11:13 PM
Mesa, Arizona
6pak2go Offline OP
6pak2go  Offline OP
Mesa, Arizona
Hi all,
I'm looking for a source or options to find a passenger side door window slide. It's the forward piece that slides in the vent window frame. Looks to be felt covered plastic and held on to the window with plastic clips.
Car is a basket case '67 Barracuda Fastback that for some reason the PO took apart the door window glass assembly and probably broke/lost the window slide.
I've searched several sites, but no luck. Any ideas would be greatly appreciated.
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: A-Body Door Window Slides [Re: 6pak2go] #1588183
03/05/14 12:13 AM
03/05/14 12:13 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Mopar part # 1-02932230
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: A-Body Door Window Slides [Re: 6pak2go] #1588184
03/05/14 12:25 AM
03/05/14 12:25 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Weatherstrip with slider/clips #2932230. Slider/clip alone is #4198752. As of Nov 2013 they were still available from Chrysler. They are also available from most restoration places and ebay etc.
http://www.ebay.com/sch/i.html?_trksid=p...0&_from=R40
Some threads regarding them. Note; A and B bodies use the same one.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=7921510&an=0&page=0
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Re: A-Body Door Window Slides [Re: 6pak2go] #1588185
03/05/14 08:10 AM
03/05/14 08:10 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
E-berg sells them on Ebay.
"I think its got a hemi"
Re: A-Body Door Window Slides [Re: 6pak2go] #1588186
03/05/14 05:11 PM
03/05/14 05:11 PM
Mesa, Arizona
6pak2go Offline OP
6pak2go  Offline OP
Mesa, Arizona
Wow, thanks for the links and info. I'll stop by my local Chrysler dealer on the way home tonight. You guys are awesome!
Robert R
Mesa, AZ
